Gear or Hydrostatic Transmissions for Compact Utility Tractors?
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #371
My grandfather said we had to keep an Allis Chalmers on the farm to jump start the M and A Farmalls. Once we converted them to 12 volts we were good to go. 😀
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #372
Nope, not always... Just in the fall when I know it probably will be used for firewood...
Actually I've pulled a loader tractor to start it too, just run the chain under the bucket and it will lift it enough to bump start the tractor.
SR
Well, that's how the tow-truck had to hook up to my HST IH2500b tractor loader to get it on the roll-back. :laughing:
But it wasn't because of a dead battery. Eventually found the gear on the distributor had spun off.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #373
For YOU... BUT not all of us have or even want a loader on every tractor... And, THAT would be me. SR
I also have a non loader tractor, but the circumstances where I could pull start it have yet to happen. What's wrong with jumper cables?
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #374
I think he's getting at in a pinch, you can pull, push, or roll start a geared tractor whereas you can't a HST tractor, that's all. Its not a selling point to most folks. In fact, its probably an unknown point to most folks these days.... as in, they've never push started a car, either. :laughing:
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #375
I've push started a truck several times with my tractor.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #376
We used to push start vehicles often when I was a kid. I specifically recall us kids getting out of our VW van and mom telling us to push it down the gravel driveway to the street, because she couldn't pop the clutch in the gravel and get enough traction to start it..... my mom... she taught me to push start a car! I miss her. :)
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #377
SR
Been there done that! Works like a charm!
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #378
Back in the "old days" I push started many cars and trucks. But things change..
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #379
We have three vehicles. Two are manuals. My F150 is an automatic because for some inexplicable reason you can't buy a full size pick up in this country with a manual, otherwise we'd have three manuals. My wife's car is a 2009 Infiniti G37 Coupe. She ditched her G35x Sedan because she hated the automatic transmission. I drive a 350z, manual of course. Our days of driving manual cars are numbered as fewer and fewer makers are producing them anymore. I'd happily step up to a double-clutch paddle shifter but those are pricey. All other automatics, even the ones you can "shift" (what a joke) just suck in my opinion.
My tractor is a gear model. Never had to push start it. In fact, the battery is the original, 10 years old, and fires every time.
I like geared tractors for a number of reasons. I'd enjoy the convenience of a hydro for a lot of reasons. My two primary reasons for going geared where price and simplicity. Its been paid for for a long time so now it is just simplicity. If it breaks, chances are I can fix it even if it has to be split. If a hydro breaks I couldn't touch it.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #380
The hydro is in many ways simpler in construction than the gear and clutch system. And is an order of magnitude simpler than the Kubota Glide Shift system. Not that those systems are bad or give much trouble either. Hydrostatic transmissions are not complex.
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
TANK MANIFOLD (A55745)
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
1607 (A57192)
1607 (A57192)
