Gear or Hydrostatic Transmissions for Compact Utility Tractors?
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #282
Overheating.
How would you overheat it?
Plug the transmission cooler and ignore the overheating warnings?
That would probably plug the radiator, too, and that would overheat the engine on both a gear and HST, wouldn't it?
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #283
Did anyone already cover the fact that compared to a gear tractor, an HST tractor of the same size and capability with the required larger engine so that it does not feel like a dog cost a bunch more money!!! That has got to be the single biggest reason to have a gear CUT. I know it's my reason.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #284
I really think there are 2 main reasons that gear users say a gear is better.
1) they have a gear and need to say it's better to justify their expense. That's a reason many people rave about many things they purchase.
2) Testosterone. You can't be a real man unless you shift gears in your tractor, truck or car. Shifting gives you a feeling of power and control.
I found this answer to be hilarious, really dumb but hilarious... lol
I own both, but if I could only have one, it would be gear...
1. you have to be kidding!! Hydros cost more to buy, and also cost more to own too...
2. that may have fit you, but it has NOTHING to do why "I" prefer gear drive. I've stated several reasons why I prefer gear drive in earlier post, so I won't repeat them AGAIN here...
SR
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #285
Quite likely.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #286
SR
You cherry picked out the part of his quote where he said....
If you're happy with your 'system' then that's good and it's all that matters.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #287
Sure I did, why?? Because HIS 1. and 2. are WAAAAAY off base and I wasn't about to let them stand.
SR
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #288
SR
They aren't way off base at all. Sounds like he touched a nerve... there's a whole bunch of good reading out there by a couple fellas named Erikson and Freud that might explain it better than he can.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #289
Right on the money SR.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #290
#2 is a completely subjective guess and not worth talking about. But I'm interested in how you can support that #1 is correct in any way?
When it comes to the money, and many HST fans hate when I bring this up and say it's an unfair comparison, but you can buy a next frame size up gear CUT with a larger engine and larger loader and larger everything for the size of a smaller HST. And that larger gear tractor can out work the smaller tractor doing just about everything most people do with a tractor. Yes, there are a few exceptions. But dollar for dollar gear kills HST.
2008 International 7500 T/A Altec A77T Bucket Truck (A55973)
2008 International...
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
Case Titan 3530 (A56435)
Case Titan 3530...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
Ford 8510 (A53317)
Ford 8510 (A53317)
