Gear oil on the BX deck?
   / Gear oil on the BX deck? #1
r0GuE
West PA
ex-Bota Owner
My deck started sounding a little different yesterday. I'm not certain it's a problem, but I'm concerned enough to double check my gear oil today. I was wondering if I should have done this earlier.
How often do you check the gear oil on your decks? I have never done mine (at 102 hours). I'll be doing it today. I do grease the deck fairly often (every 10-20 hours).
Also, I believe I am to just fill it to the top hole right? Anybody doing anything fancy here? synthetic?
   / Gear oil on the BX deck? #2
I check my deck oil every time I grease it. I grease my deck about as often as you do. I believe Kubota reccomends changing the oil in the deck at 50 hours also and there after every 150 hours. Check that though as I migh be off. Also, I have the ground contact deck on a B7500 so I'm not sure it's the same for yours.
I just changed my oil in my deck for the first time. Here's a hint.....don't remove the drain plug first as it was under pressure after finishing the lawn and shot about five feet across the floor. What a mess!!!! I removed the breather which has a spring loaded check ball and found it to be working fine so I guess that's normal. Trying to remember if I have ever changed the oil in anything and not gotten some on the floor no matter how careful I was....
Jeff
   / Gear oil on the BX deck? #3
The gear oil on my MMM has never been changed, although it was checked the last time the machine was serviced. (This deck was on my BX2200 for a few years and is now used on my BX22). There is a noticable difference in sound level right after normal lubrication, however...much quieter. For that reason, I'm greasing twice a season now whether it needs it or not! I suspect that if you do a LOT of mowing, then the oil will need attention sooner than someone who mowes an average of once every two weeks through the season.
I have noticed the quiet operation post greasing. I pulled the deck off this AM and checked the oil level. It is ok. While I realize that it is to be done every 50 hours, I am guessing that it is just about 50 hours now, since 1/2 my tractors operation is loader and other uses (estimation). Either way,... I figure I have only 2 or 3 mowings left this year, so I am waiting until the season is over and I will go over it really well. The blades need sharpened etc. I did grease it and that seemed to help the sound level a bit.
   / Gear oil on the BX deck? #5
I sent an Email to Kubota relating to the frequency that the MMM should be greased. Here is their response:
"Thank you for contacting Kubota. I suggest that you grease them after each ten hours of actual use. Apply grease until you see excess grease slightly weeping from the spindle shaft seals. This should ensure a long and reliable life for your mower."
Not sure why they did not include that information in the MMM Operator's Manual.
John
   / Gear oil on the BX deck? #6
I check mine every 10-12 hours, when I do the grasing, etc. When at was at my dealers, I saw a BX MMM that a municipality had run out of gear oil. The dealer had guessed that it had never been checked.
Will
   / Gear oil on the BX deck? #7
I grease my every 10 to 15 hours.
I would change the gear oil out around 200 hr on the deck and fill it with a nice syntheic oil. The oil is cheap since it takes a very small amount (less then a qt).
John Deere 7000 Corn Planter (A49251)
John Deere 7000...
Bobcat 5600 Toolcat 4WD UTV (A49251)
Bobcat 5600...
2011 Chevrolet Impala Sedan (A48082)
2011 Chevrolet...
2019 FORD F59 STEPVAN (A50046)
2019 FORD F59...
TPM 16 Mini Excavator (A49251)
TPM 16 Mini...
2005 IH 7600 t/a Dump Truck (A47371)
2005 IH 7600 t/a...
