Gear oil leak on Farmftrac-60
   / Gear oil leak on Farmftrac-60 #1
miniracer26
farmtrac 60
There is a drain plug under the transmission, and in front of it about (about 10 inches or so) is a hole with a cotter pin sticking through it. I noticed gear oil leaking from this. There is no way to remove the cotter pin as it is coming if from the inside. Is this normal?
   / Gear oil leak on Farmftrac-60 #2
What you are lookig at is bell housing for the clutch assembly .The hole in the drain plug is called a weep hole. It is there to let unwanted fluids out . Such as oil.The cotter pinis there to keep the hole from plugging up by moving around when you drive around .The gear oil indicatets a front trans seal leak.
Thank you for the info. Do you happen to have the operators manual? The link that was posted doesn't work.
I was hoping that was what was supposed to be there.
198367 (A51243)
198367 (A51243)
UNUSED HURRICANE 5' X 10' CONTAINER (A51248)
UNUSED HURRICANE...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2020 CAT 239D3 Skid Steer (A51573)
2020 CAT 239D3...
