Mowing Gear lube leaking on mower gear box out of vent
   / Gear lube leaking on mower gear box out of vent #1
RMatty
North Windham CT
BX 2350
Hey everybody, Was wondering if anyone would know why oil leaks out of the vent on my 54in fine cut deck gearbox? Ive checked the obvious like the gear oil level and actually took a little out to drop the level but still continues to leak. I do mow some pretty steep hills on my lawn, could that be contributing to the oil leakage? I brought it back to the dealer and they pressure tested the seals and they said everything was fine. Could i take the vent out and put a solid bolt in its place or will that damage the gear box?
   / Gear lube leaking on mower gear box out of vent #2
I have a 60" non fine cut deck and mow some pretty steep hills and don't have any leakage. One thing I have found is that at certain engine speeds, it seems like the belt well go into a kind of harmonic vibration. Leave your belt guards off for a minute and see if you get this vibration in the belt. Just a guess but this could cause the oil to shake out of the gear box.
   / Gear lube leaking on mower gear box out of vent #3
Heat, expansion, pressure. Everything is subject to this. Do remember that the dip stick typically has a range. If you fill it to the top, you normally see some leakage, nature doing its job. Solution, don't always keep everything topped off to the max. Better to be between or just below the lines then over the line. If it did not vent you would eventually open up a gasket/seal. Your situation is quite normal.
   / Gear lube leaking on mower gear box out of vent #4
I agree with RaT...
It sounds like you have a new mower, which probably has the oil topped off in the gearbox. I would check the level every now and again. Also, if, by chance, the oil was an incorrect viscosity (thinner) it might be more likely to come out the overflow.
I would think, however, that what you are experiencing is normal due to heat and expansion. Just keep an eye on it.
   / Gear lube leaking on mower gear box out of vent #5
This is a good question. My father has MF RFM with same issue and still trying to talk to others about it. He had to replace the gearbox once and rebuilt once. He never had a problem when he first got it till now. The dealer put a breather tube on it to prevent seals from blowing out again, but it still boils over to through the breather tube. I would be watching this thread if anyone has an idea what to check.
   / Gear lube leaking on mower gear box out of vent #6
If the breather is in a bolted cover that can be repositioned, perhaps the cover is installed incorrectly and the breather is in a splash zone from the gears inside. Perhaps the oil is carrying a little water and foaming, causing the breather to vent some oil.
   / Gear lube leaking on mower gear box out of vent #7
Again, heat, expansion of the fluid and air in the gear box needs venting. In a closed system like your radiator there is a method to allow for this via the cap and the recovery tank. Some gearboxes express themselves with signs of oil at the vent site. No big deal, that's just how it works. The front axle on my Kubota does it, the entire transmission on my Kubota does it, its physics. Look at the vent on the rear end of a rear drive vehicle. Unusual to see much in the way of oil there but there is also considerably more real estate to keep the oil from ever getting that far.
   / Gear lube leaking on mower gear box out of vent #8
And yet most mower gearboxes do not vent oil. Some do; usually with cause, sometimes not.
   / Gear lube leaking on mower gear box out of vent #9
Any chance of water getting in the gearbox? [Condensation]
Can you extend the vent?:D
   / Gear lube leaking on mower gear box out of vent #10
I have a Woods PRD8400 finish mower. I also get some oil through the breather at the top of the gear box. This is normal. Once the fluid level drops a little bit, like others mentioned, it should stop. Only worry if you see oil or debris sticking to the sides and bolts of the gear box. On the top around the breather is just fine.
I clean the gearbox off once in a while and the oil gets less and less over time. Right now there is no oil coming out and the oil level is just slightly below the fill plug on the side of the gearbox. Still plenty of lubricatin going on in there :D
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
(1) HD 24ft Free...
STORAGE FEES (A52576)
More info coming soon! (A50322)
More info coming...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
