Comparison Gear driven or HST
/ Gear driven or HST #61
If you go back and read most of the threads (over the last ten years or so), you see I mostly promote gear transmissions rather then demote HST.
You're correct...most responders do not have adequate experience in both types of transmissions to make an educated post on the merits. Even the relatively few hours I have on HST is likely more then most have on gears.
What I mostly promote is the OPs get on the tractors and see what they prefer most. They are the ones going to be living with their decision.
But, it's just an internet forum and harassing the girlyguy HST owners is fun. That's what it boils down to...
Reminds me of an old saying: "Cows may come and cows may go.....but the bull in this place goes around forever!".
Moral: Don't rely on any ONE poster....cause just like the press....we all got some bias in us. Some even have a little bull. ;) Listen to folks, but do your own research on important issues. Kinda like voting. :D
/ Gear driven or HST #62
I think you have them mixed up. I have replaced clutches, disks and plates. The labor is getting to it... not the expensive parts. A bobcat with the seperate sunstran pumps for the hydrostatic is just as labor intense and fifteen times more expensive. Nothing is cheap about hydrostats.... ever fix one? Probably not because they are replaced, not repaired.
I had a TC45 NH that I listened to the hydro whine for three years. Went to pull another tractor out of a sink hole and it had a terrible time trying to spin those large tires when weighted down. Traded for a TC 55 with power reverser and have never been happier. If I can't find a range in twelve gears it isn't worth doing. The hydro pumps never seem to have the power to efficiently run the drive and loader at the same time. This is true of tractors less than 100 hp. My Deere lawn machine ( 4110 ) is hydro and for minimal tasks it works just fine. Depends on the task.... pulling a chisel plow gear... getting the mail and grading the drive hydro. Each has a place but I will never believe a hydro can be repaired cheaper than a clutch.
I should have made it more clear... What I meant to get across was that I believe it's about $3000 to replace a clutch, yes, mostly labor due to the tractor needing to be split and such. However, with everything I have read about how strong/bulletproof the HST's are now days and it's only about $1000 more +/- to upgrade to a HST over a gear model when buying new, then you might come out ahead in the long run. Now, that being said, I can only imagine that if you did have some issues with the HST it would most likely cost a pretty penny if not covered under warranty.
I have had no issues with my manual/partially syncro transmission or clutch. I do however do lots of loader work and not much of my property is flat. I often wonder how hard I am on my clutch and just how long it will last. I guess time will tell because I don't have any plans of trading mine in.
/ Gear driven or HST #63
I liked the unedited version much better! Just sayin.....
/ Gear driven or HST #64
You mean when I had: Cow's may come, and cows may go.....But ROY'S BULL goes around forever. :D
That one? :D ;) After some thought....I removed Roy's name...cause he and I go back a long time....and we both owned JD 790's at one time.....and I can forgive him for being so hard boiled to buy another gear shift tranny.....even when he knows there is better to be had (for his purposes his is fine - not for me).
Case in point tho....I had bought a 790 at one point, primarily because it was low cost for my deer land, and I had an infrequent need and thought I could get along with a no-frills, gear shift tractor.
After two years it became apparent that I had miss-cued on the 790 purchase (also needed better hydraulics and a bit bigger to run a few new implements like my grapple and stump grinder, etc) so I upgraded to an ehydro unit. Got my purchase price back from the 790....and I'm happy with my current ride - which has the eHydro and other good equipment.
Moral: If you buy right.....you can upgrade or sell right.....and not lose your shirt. Me?....I buy good stuff that is a few years old and wears green paint. ;) I think I've owned about 8 JD tractors over time....they are all good.
/ Gear driven or HST #65
That's the one....I have been doing some reading here on the forums and I have discovered some interesting facts about Roy. He seems to like quiche and prefers alpacas over sheep. Very Interesting!:shocked:
/ Gear driven or HST #66
I like quiche???
As far as the other comment...well, I'll leave that to you BAAAAAAAAAAAAd boys!
/ Gear driven or HST #68
I'm not naming names, but the term "Reaction Formation" keeps coming to mind.
/ Gear driven or HST #69
I have a manual/gear that I bought new. If I ever do it over, it will be a HST without a doubt. In addition, I've heard its about a $3000 job to replace a clutch where as its only about $1000 more for a HST so its probably much cheaper in the long run.
$1k more at the initial purchase, but probably closer to $5k if it needs to be replaced.
/ Gear driven or HST #70
Although I'm a gear guy, I'll wager I've read of no more then 7-8 HST failures since I've been on TBN.
Haven't read of too many gear tractor clutch replacements that weren't on recently purchased used tractors either (meaning the clutch was either abused or near the end of it's life when the tractor was purchased).
/ Gear driven or HST #71
Agreed. Many folks prefer to trade up when they're facing a $2-4k clutch replacement invoice.
/ Gear driven or HST #72
This gets this thread waaay off track...but it's heading that way anyway. ;)
When I got married I owned a 62 Chevy SS Convertible. It was a VERY nice car.....and I was about flat broke and the clutch went out of the car one Friday. The cost to replace the clutch and pressure plate (and IIRC a flywheel?) at the dealer was around $300 - which I didn't have.
Rather than fix the car....I traded it (sniff) for a BRAND NEW SHINY FORD MAVERICK. I can still remember the price was $2026. ($1995 + big wheel covers, radio, "big" six engine, AT, and heater and keys = $2026. sticker price) That moment was the start of my downfall....but I did get to work on Monday. :laughing: .....and my kid ate dinner.
Talk about a reality check. And, I'd do it all again. :)
/ Gear driven or HST #73
Just think what that 62 SS convertible would be worth now if you could have put it away and kept it...I know.. you needed to get on with life, and did what you had to do... I swapped a 73 Pontiac Grand Am for a 78 Grenada too... boy was that a bummer... But gas went from low .40 to over .75 cents a gallon and I was getting worried:shocked:. That old 400 in the Pontiac would really move it down the road, and the Grenada was like stepping on a plum. Squish. Oh well.... and life goes on.
James K0UA
/ Gear driven or HST #74
James K0UA
You guys are breaking me up, I went from an SS396 to 71 Super Beetle; in college with a family, you know how that goes...
Sounds like we all came from the same generation. I had a 67 Chevelle SS396 4 speed. I now have a 86 and a 89 Mustang, both manuals, so I'm no stranger to clutches on cars. Replaced a few on cars but getting to old to crawl under them now.
Getting back to the tractor. I think I'm going to go with the Kutoba L3200 with HST. I know my wife and daughter can handle the HST a lot better. I think I'm getting a pretty good deal from my dealer and Kutoba is offering zero interest for 60 months.
Thanks to all that has offered there comments it has really been helpful.
/ Gear driven or HST #76
If you are not going to engage the ground directly and part timers (the wife and others) are going to use the tractor, go HST.
If you know how to drive a clutch and understand what's happening in a geared machine, and want to engage the ground, go gears.
HS
/ Gear driven or HST #77
Congratulations, how are you going to set it up; rear remotes, SSQA, bucket hooks, loaded tires tire type...?
/ Gear driven or HST #78
Good deal, the Kubota should work well for you. Don't think that you will have any problems with a hydrostatic tractor for ground engagement on a small scale either. To clarify, gear drive is more efficient for steady plowing which is important for real farming but for a wide variety of uses on a residential setting the hydrostatic is a good choice. You can do some high draft work with a hydrostatic tractor without any damage to the transmission but it will burn more fuel.
My thoughts are that for most members here using a compact tractor on small acreage the increased efficientcy of a gear tractor isn't enough to make up for the loss of convienience that the hydrostatic offers. I suspect that gear transmission offerings will all but dissapear from compacts and most of the manufacturers have limited offerings in gear tractors for a reason. Easier for most people to operate in close quarters.
Not sure about the rear remotes or SSQA. No bucket hooks. The tires are industrial R4s loaded.
/ Gear driven or HST #80
Not that you asked, but a hydraulic top link is one of the handiest things I have ever put on a tractor and I can't believe I went so long without one, we have them on our L5740 and M8540 (5740 has 3 with TnT, but that's a recent addition. I also use my bucket hooks often and they are a cheap add on. Other stuff, but you didn't ask, so I won't go on.
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A64194)
Pemberton Inc...
HORST RSW HEADER CART (A64278)
HORST RSW HEADER...
16in. Bucket with Teeth Excavator Attachment (A64194)
16in. Bucket with...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A64557)
2005 Freightliner...
