Tiller gear drive vs. chain drive tiller
   / gear drive vs. chain drive tiller #1
sawyer22
Churchville, ny
john deere 3720
I am looking at a tiller for my JD 3720 (44 hp) - "everything attachments" has a Korean made 62 inch gear drive tiller for $2138 or a 62 inch chain drive for $1991. Is the gear drive worth the extra $147? Thanks
   / gear drive vs. chain drive tiller #2
I would go with 'gear drive' for a tiller that is over 60 inches.
   / gear drive vs. chain drive tiller #3
i say dear drive with 44hp if you go chain you will break the chain in a few mins of use
   / gear drive vs. chain drive tiller #4
I wouldn't go that far, but I will repeat what Ken Sweet( www.sweettractors.com ) said "in 30 years, I have sold 2 chains for tillers, but I have no idea what make they were".
   / gear drive vs. chain drive tiller #5
If the tiller has a good quality #80 or #100 chain, you won't have any problem with using it behind your 3720. That said; I would want additional info regarding the build quality of the Korean built tillers.
The bearings, shafts, etc. might fail before the chain... ;)
Typically, don't find gear-drive tillers until you're up above 50-60 hp and into the 6.5'-15' widths. Commercial duty and heavy Ag purposes.
AKfish
   / gear drive vs. chain drive tiller #6
I have a Befco 54", chain driven, side shift tiller that I bought at Rural king 20-25 years ago. I have never replaced the chain once, maybe a couple of hundred shear bolts though. I have run it on 19hp to 50hp tractors and it just keeps on tilling. I plan to go thru it this summer and replace the bearings and seals look the chain over and repaint the old beast. If the chain looks good I will see if it will run another 25 years.
   / gear drive vs. chain drive tiller #7
I don't think it matters whether you have chain or gear drive. Look at the overall build quality and price to decide.
   / gear drive vs. chain drive tiller #9
I am in the it shouldn't matter group. You can have a chincy under designed drive either way. I like chain drives on stuff that might jam. Look at all the gear engagement you have to spread the force over vs one tooth on a gear drive. And 20 years down the road it will be easier to find or make a chain than to find a mating gear.
I would go with the best quality unit.
   / gear drive vs. chain drive tiller #10
With the 44 Hp you could easily handle a 74 inch unit. I have an Ansung which is great - see my sig. I posted so great places to buy a while back. I also recommend gear driven .
Also check out your local AGG rental for a good by on a used unit too. They tend to rent the more durable units. That's how I got mine
Case 1825 Skidsteer (Non Running) (A50515)
Case 1825...
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
New Holland 939 3 Row Corn Head (A50774)
New Holland 939 3...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
Agco S150 Manure Spreader (A50774)
Agco S150 Manure...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
