gear boxon a John Deere 666 3 point snowblower
   / gear boxon a John Deere 666 3 point snowblower #1
sleepydeere
Woolwich, Maine
4052 R John Deere
Hi what to run in the gearbox, I just purchased the blower ,I want to grease it and change the oil in the gear box and lube the auger chain before I use it. this summer I will paint it, any info would be great thanks Mark
   / gear boxon a John Deere 666 3 point snowblower #2
I would think 80W90 gear lube will work just fine.
A synthetic 75W90 could also be used if you wish.
Good Luck!
Thanks for the reply, Mark
   / gear boxon a John Deere 666 3 point snowblower #4
My vote would be for some Mobile 1 gear oil. You are going to be using it when it is cold so get some stuff that will flow..
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2010 KMC 3376 Peanut Combine (A55301)
2010 KMC 3376...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
2014 Ag Spray Schaben Sidedresser (A55301)
2014 Ag Spray...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
