Gear Box Fluid in MMM
   / Gear Box Fluid in MMM #1
AMR
Woodbury, CT
B3030
I changed the front axle fluid in my B3030 this weekend and decided to pull the mower off while I was waiting to clean it up and grease it.
It struck me like a brick that I have never even looked in the gearbox. I grease it without fail and keep it clean but the gear box just flew right over my head. I pulled the filler bolt and the level looked just fine but I probably have a hundred hours in it.
I decided that I would pick up some 90 weight oil to change it and when I looked at it, how the heck do you drain the oil without making a mess? I thought I would just pick the deck up but I am fearful of racking it when I am lifting it. Any good ideas out there?
My plan for now is to use a plastic cup to catch what I can and let newspaper get the rest. Ahhh the smell of 90 weight on your hands in the morning.
   / Gear Box Fluid in MMM #2
I've used a very small, low-sided tin foil pan for the mmm fluid drainage. No matter which method you use, you're always going to get some that seeps by your drainage container
   / Gear Box Fluid in MMM #3
I use a empty tube from a paper towel roll and cut it in half (long ways) and drained into a shallow pan
   / Gear Box Fluid in MMM #4
I use a cheapo oil drain pump that I bought at Sears. I think I paid less than $20 for it. Since the gear oil is thick, I have to keep pumping the handle to drain but since there isn't a lot of oil in the gear box, it doesn't take long and I don't spill any oil on the pully or belt.
   / Gear Box Fluid in MMM #5
When I changed the gear oil in the MMM I used duct tape to hold a quart size zip-lock bag under the drain plug. It worked very well. I taped the bag in place, removed the drain screw, removed the fill screw and propped up the deck to hasten the process of draining. I didn't get a drop of oil onto the belt or the deck. I left it like that for 20 min or so to let the oil drain.
However I did spill some oil when filled the gear box with the fresh SAE 80-90. Used one of those bottles with the tapered top and filled with oil to the top. The problem was that I had to make sure the plastic bottle didn't suck any of the oil back so I kept pressure on it after I replaced the top screw. Hence. When I pulled the bottle out some oil came spilling onto the deck. Not too big mess tho.
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
2023 Chevrolet Tahoe SUV (A59231)
2023 Chevrolet...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2011 CATERPILLAR 279C SKID STEER (A60429)
2011 CATERPILLAR...
2014 KENWORTH T800 HYDRO EXC VACUUM TRUCK (A59823)
2014 KENWORTH T800...
