G'day Everyone... New to this.....
   / G'day Everyone... New to this..... #1
wercs4me
Iseki TL2800
G'day everyone... I am new to this Forum... I have a 150 acre property in Kilcoy Queensland Australia.. We have a Massey Ferguson 184-4 Loader with a few attachments, and and Iseki TL2800... Going to run a Fert/Spreader on the Iseki... can anyone tell me the PTO speed and gear ratio to run the spreader. Thought I would ask, instead of the trial and error method. TIA BoB :)
   / G'day Everyone... New to this..... #2
Welcome to TBN & the forum - wercs4me. I would take a stab at 540 rpm as a starter for the PTO. And I'd run the Iseki at a fairly slow speed. If you have access to an owners manual for the spreader - that might give you an idea of the land speed to get the correct application. Do you know the brand of spreader?
   / G'day Everyone... New to this..... #3
G'day from the Great White North... eh...
I'm going to guess.... A 6 spline pto = 540 rpm
A 21 spline = 1000 rpm...
Have you had any of the fire or flood troubles in that part of the country ??
   / G'day Everyone... New to this..... #4
Welcome to TBN Mate.
Can't help you with the questions. As others have said, I'd assume 540 PTO speed. Ground speed, I have no idea. :)
   / G'day Everyone... New to this..... #5
G'day Cobber and welcome to TBN from Tassie.
Enjoy the site.
   / G'day Everyone... New to this..... #6
:welcome: to TBN...enjoy.
   / G'day Everyone... New to this..... #7
Most fertilizer spreaders I’ve used including my lime/fertilizer spreader give a 40ft width spread at 540pto speed , then set your ground speed to the gear that gives you the rate per acre you want to apply. Any spreader I’ve used has a chart affixed to it that shows weight of material in pounds per cubic foot, gate opening in inches and speed to travel to achieve desired rate per acre.
Thanks everyone... Info. is much appreciated. :)
   / G'day Everyone... New to this..... #9
Welcome to TBN, hope you solved your PTO speed and gear ratio information for your spreader.
KC
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
CLARK GCS20MB 4K CUSHION TIRE LPG FORKLIFT (A52472)
CLARK GCS20MB 4K...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXATXDH646719 (A51572)
2013 Dodge Charger...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A52748)
2022 NEW HOLLAND...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
