GCK60-23BX
/ GCK60-23BX #1
lmaini
Lehighton, PA
Kubota BX24
Hi All,
Long time listener, first time caller...
I just picked up a used grass catcher (GCK60-23BX) for my BX24. The manual is a little vauge and I had a few questions about set up.
1 - Is there a baffle required for the 60" deck. I did not receive the installation instructions for the boot kit, so I`m not sure if I`m missing a piece. The brackets are pretty striaght forward, so I`m all set there.
2- On the PTO shaft, is there suppose to be any type of lock to keep the yoke on the shaft. Any PTO shaft I have used in the past has a quick disconnect style or a sping loaded lock bar type retention device. The PTO yoke on this shaft has a hole drilled for the spring loaded lock bar, but it doesn't look like there was every one installed. I realize the shaft really can't come off because of the tight fit of the bagger, but I just want to be sure.
3- There is a 6" piece of hose that goes from the blower to the bags, this hose is in bad shape. Is this suppose to be a piece of vac hose or a formed elbow of sometype.
If anyone has some pictures of the unit it would be appreacated, they would be worth a 1000 words.
Thanks for the help - Lee
/ GCK60-23BX #2
On my GCK60-23BX catcher;
1. My instruction manual for the boot kit only details the installation of the mounting points for the RCK decks. There is no mention of baffle plates and my RCK54-23BX deck does not have one.
2. There are no locks on my PTO shaft.
3. The connection between the blower and the catcher is a section of corrugated hose.
My catcher is in the barn and the lawn is still way too wet to even think about trying to obtain any installed pictures. I was a little shocked with the initial quoted price of a new catcher. Once I saw the catcher mounted on the tractor and started using it, I was very impressed and I think you also will enjoy your new addition.
/ GCK60-23BX
Wild Bill,
Thanks for the reply. Looks like a couple pieces of vac hose and I`m all set.
/ GCK60-23BX #4
Would anyone want to fax me a copy of the set up. I just pick up a used one and need to see how it set up and mounts on the tractor. If someone has one on disk or cd maybe you could email what I need.
/ GCK60-23BX #5
I have bought the grass catcher for my BX24 as well. I hope to start installing this weekend. I couldn't believe how huge the box was that it came in. Then I opened it up and understood why. My dealer didn't have any to see when I ordered it. I had no idea what I was getting. So far just by the size I am impressed. Once you get yours working let us know how it does. I probably will not need to use if for a couple of weeks yet.
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
More info coming soon (A61574)
More info coming...
2013 WESTERN STAR  4900 SB (A65643)
2013 WESTERN STAR...
36in AIM Bucket w/ Teeth Excavator Attachment (A64194)
36in AIM Bucket w/...
25in Wagon Wheel Chair (A65583)
25in Wagon Wheel...
