GC2600 Steering wheel removal
   / GC2600 Steering wheel removal #1
wrangler6831
WV
2- 65 M-F, 6245 Zetor /loader, GC2600 M-F /loader, BX24 Loader/BH
Has anyone had to remove the steering wheel yet? I had a little accident with my dash and need to replace the surround but I cant figure out how to remove the steering wheel. I removed the nut and tried turning the center with a allen wrench but it didn't seem to move. Also tried a gear puller hooked under the wheel, which is almost impossible... Anyone have to do this yet? Hints , tips would be appreciated.
Rich
   / GC2600 Steering wheel removal #2
If you have a puller that bolts to the wheel you can put some tension on the wheel then hit the center pin on the puller with a not to hard hit to break it loose. A puller hooked on the back side of the wheel will work but could do some damage to the wheel.
When you put it back on apply some anti-seize to the splines to make it easier next time.
   / GC2600 Steering wheel removal #3
After you remove the nut, it should just slide off of the spline/shafts..............maybe use a little penetration fluid !
Tried just lifting on it today while hitting the center bolt with a brass punch and hammer, no luck. There is no bolt holes in the wheel to bolt anything to, so the gear puller is what I tried but the bottom of the wheel is tapered so no luck there. There is a piece under the wheel that oddly shaped, maybe for a special tool. If you don't have a GC series then you most likely wont know what it is. Im going to try to contact my dealer tomorrow and see what they say.
Finally got it! I had to use a 3 jaw puller and fasten all 3 jaws to the center bolt to keep them on the taper at the bottom of the wheel. There are no bolt holes to use a traditional wheel puller on.
   / GC2600 Steering wheel removal #6
Using a 1" pickle fork in between the bottom of the steering wheel and the top of the column shroud works awesome.
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
Polaris Sportsman 335 4x4 ATV (A51573)
Polaris Sportsman...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2000 Isuzu NPR-HD Landscape Truck, VIN # 4KLC4B1R9YJ802689 (A51572)
2000 Isuzu NPR-HD...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
