Mowing GC2600 Bush Hog
   / GC2600 Bush Hog #11
I have a 4 foot Buhler behind a GC2610. As others have said, a five foot would be a struggle.
   / GC2600 Bush Hog #12
I run a 5ft on my 1529. I think it would be more of a weight issue than a HP issue with your GC. My 1529 does not have much more power than your GC. I was told a 6ft cutter would work with mine but I'm glad I went with the 5ft. I like the cutter being the same width as the tire track of the tractor.
   / GC2600 Bush Hog #13
I recently purchased a King Kutter 48" brush cutter and am using it on a 2610. Only problem I have encountered is trying to cut too much too soon. I had my deck set too low and cut too much too soon. I adjusted it higher and then make 2 - 3 passes to get to ~ 2" above ground level. Otherwise the tractor works fine with the 48" cutter.
   / GC2600 Bush Hog #14
What model did you get? I'm assuming that with the 2610 you had to get the XB?
   / GC2600 Bush Hog #16
FarmerCog said:
I purchased the L-G-48-40-P model.
Are you able to get good lift on that model?
   / GC2600 Bush Hog #17
With the rear wheel mounting bracket at the mid position I can get ~ 16" at the rear of the mower with PTO at max.
   / GC2600 Bush Hog #18
Rotary Cutters are Dangerous...Rotary Cutters are Dangerous. The 2400, 2600 and 1529 are nice tractors. I personally would not feel comfortable operating one with a five or six foot rotary cutter on the rear. The weight of the rotary would in my opinion make the tractor very unstable on anything other than very smooth terrain.
   / GC2600 Bush Hog #19
Bought a used brush hog for my 2410 last year. It is quite old and extremely heavy duty. At 4' I thought it was maybe undesized but it's perfect for a small tractor. I've used it to cut a field that was near 3 years over due, cut overgrown trails and create new ones. Tractor has more than enough power to run it just be careful to walk out what your doing first. Oh, stock up on shear pins and make sure the gear case has fluid.
I'm very impressed with my 2410 it has way more power than I expected.
   / GC2600 Bush Hog #20
I have a Woods 54" brush hog and it works good on my GC2410, :thumbsup:. KC :D :D :D
2017 CATERPILLAR 246D SKID STEER (A52705)
2017 CATERPILLAR...
UNUSED RAYSKY RM87-96 MOBILE TOILET (A54757)
UNUSED RAYSKY...
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
2012 UTILITY VS2DX DRY VAN (A54607)
2012 UTILITY VS2DX...
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55218)
2014 Volkswagen...
