GC2410 Temp Gauge Not Moving After Start
   / GC2410 Temp Gauge Not Moving After Start #11
it should be running around 180F . if it runs cold it will wear the cylinders out a lot faster. the clearance will not be up to specs when running too cold or too hot. hares a cheap tool that can be handy, point it at the top of thermostat housing to get a good reading of the temp. https://www.harborfreight.com/121-infrared-laser-thermometer-63985.html
This is solved I hope. Was the temp sender connection. I checked to make sure the gauge was good by grounding it(went to the top like you and the Agco mechanic said it would). Then I cleaned the connection and made aure it was snug after checking upper (141f) and lower(121f) hoses were flowing through.
Now it registers the temp above C. Will test it full tomorrow.
Dealer mechanic was also very helpfull.
I believe the root cause was the belt flapping around because it was so loose.
   / GC2410 Temp Gauge Not Moving After Start #13
Glad your problem is fixed. good deal
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
2004 JOHN DEERE 5320 TRACTOR (A51243)
2004 JOHN DEERE...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
Great Plains Grain Drill (A50515)
Great Plains Grain...
1270 (A50490)
1270 (A50490)
