GC2410 Coldest Weather Starting problem
   / GC2410 Coldest Weather Starting problem #51
I do not see the new thread, did you post it in the MF owning and operating forum?
Most GC owners who would read this thread, have no experience with your tractor.
But, there are 1250 series owners in the MF forum.
They are more likely to see your question, in the new thread.
   / GC2410 Coldest Weather Starting problem #52
First winter with my GC2600 and had trouble starting this morning when it was below 30F. Tried 3 times to start then grabbed a battery charger to keep from killing my battery and the heat gun I'd been thawing a pipe with. Five minutes of 1500W heat gun under the oil pan and it fired right up! So now I'm thinking about a heater too.
Started twice more later in the day after it had time to cool off without issues, and a fraction of the glow plug time (held it for 45-60 seconds each of the 3 previous attempts). I had to get more fuel so I waited until today to make sure I had the winter mix, and threw in some more additive right before topping off the tank. The new fuel was after the first start, and it was about an hour or two before I used it again. Would the new fuel have made a difference in starting? I had put some additive in the summer fuel last month, but would winter mix + additive make a difference?
My charger said the battery was at 43% charge, so it was low. Not sure if that's due to the 3 cranking attempts and plug use, or me using the LED bar as barn lights when locking the animals up each night. Planning on starting it for the heck of it tomorrow morning to see what happens. As much as I hate cold, I want it as cold or colder than last night just to see if it works better. haha :D
   / GC2410 Coldest Weather Starting problem #53
Fuel could make a difference, but I don't believe 30F is cold enough to make a big difference.
For 30F, I would open the throttle handle about an inch forward, and give it about 20 second of glow plug time.
If it doesn't start in 5-7 seconds of cranking, STOP. Cranking further, will only kill the battery.
Reheat the glow plugs, for another 20 seconds, and try cranking again. If that is unsuccessful, go back to the glow plugs, and crank again, This time, advance the throttle while it cranks, and when it starts, make note of the setting the throttle is at. Reduce the throttle to a high idle, as soon as it fires.
Use the throttle setting you noted for the next start at that temp.
Colder temps can require 30 or more seconds of glow plug time. And, will require you to open the throttle further for start up.
I have never had trouble starting my GC. Even in below zero temps, I have never needed more than two attempts to start it.
   / GC2410 Coldest Weather Starting problem #54
Thanks for the info. I'm probably not opening the throttle up enough. After this morning I started reading a few of the cold starting threads on here, and decided I needed to play with the throttle. I also have one of the silicone oil pan heaters coming in tomorrow that I'll get on, just to make things a little easier to get going and idle warm up.
I guess the more throttle should have been my first thought. I hold the throttle on my string trimmer to start, and the snowblowers and lawn mowers I've used all go through full throttle to get to choke to help start. Don't know why I didn't think the diesel would also need more throttle.
   / GC2410 Coldest Weather Starting problem #55
Well, that did the trick! Let it run the pump for 2 seconds, 20 GP (or a bit longer as I forgot to take it out of gear), and 4 or 5 seconds of cranking.
Now, I suppose I don't really need the block heater anymore. Perhaps it would be better served on the rear axle to warm the hydro fluid? And just use my heat gun for a few minutes under the oil pan if I really need it?
My concern is repeating last winter where we had a solid week or two of -11F to -15F mornings. My gas truck struggled to start and a couple days of those temps finally made me replace the 8 yr old battery that had worked fine until it wouldn't crank the truck 2 days in a row. My boss's ford diesel died in the parking lot at work 2 or 3 times during the same 2 weeks. We tried jumping it a couple times, even with 2 vehicles (one being my truck with a 140A alternator), and finally he ended up chaining a small camping generator to a tow hook so he could run a charger and block heater all day so he could drive home and plug it in! After last winter I dread those temps now.
I'm not going to want to idle the tractor for long in the barn since the animals won't want to go out if it's that cold, and they're the next bay over in our barn. So heater on the axle for an hour or so, heat gun oil pan for a few minutes if needed to start, crawl out of the barn, idle for 5-10 minutes, and clear snow sound like the best plan? Not sure I really want to start up, lift FEL, then crawl out to idle when it's that cold out.
   / GC2410 Coldest Weather Starting problem #56
Glad you had success. Yes, the air is denser in the winter, so you need more fuel in the mix. That means, you have to open the throttle some.
Also keep in mind, you need a moderately high idle speed to warm up a diesel engine. Because, they actually cool down on low idle.
A MF block heater is a nice, over priced accessory, ($125). But, I don't have to start mine everyday in the winter. Usually, I only need it once a week, or less. And, as I said, I haven't had any trouble. Now, my barn is finished and insulated enough, that it never gets much below 32F in there, making it fairly easy starting.
I have a 150 watt silicone pad heater on the bottom of the rear axle. When it runs a couple of days, it keeps the whole unit from feeling cold. I would highly recommend that.
I also have a 50 watt pad heater, on the bottom of the oil pan.
Those, coupled with synthetic hydraulic oil, (Amsoil ATH), makes it less scary to shorten the long hydro warm up times in the book.
   / GC2410 Coldest Weather Starting problem #57
Thanks. Do you have a picture of where you mounted the one on the rear axle? Or can explain where? I haven't crawl under and see what would be a good protected area yet.
Mine seems to idle between 1,000 and 1,500 RPM (so about 1,200?) with the lowest throttle. From what I've read here that would be considered high idle right? Seems like I saw some engines idle around 500 RPM. I tend to bump it up to 1,500 for warm up though. Seems to run a tad smoother at that speed, and I can do most low speed operations like raising the FEL and pulling out of the barn.
   / GC2410 Coldest Weather Starting problem #58
There are no tach's on the 1st generation GC's , so I don't have a number. But, it suffices to say, if you have the throttle advanced enough to hear a high idle, you probably have it set at one.
The pad heater is not totally protected from anything. But did fit nicely between the ribs on the case. I don't run the Baja 1000 with mine like some do, so I am not worried about it getting damaged.
   / GC2410 Coldest Weather Starting problem #59
One further note. If you have farmers in the area, ask them where they get their fuel.
I buy mine at the local supplier for many of the farmers around here. They put top notch additives in their off road fuel. I never had any issues with fuel in the winter.
Buy a bottle of Power service 911, it may be a good thing to have on hand. It seems to be the only good way to quickly get gelled diesel fuel to flow again.
Then, hope you never need it.
   / GC2410 Coldest Weather Starting problem #60
Thanks again for the info. I've been getting diesel from whichever gas station I've been passing. Manual says ultra low sulfur diesel, which is what the gas stations sell of course, so I haven't really looked for off road diesel. Wasn't sure how that would affect things. I asked the guy across the street from me, but he seemed to have trouble remembering.... He's 90, so I don't fault him! And he probably bought a few hundred gallons that's lasted him a while since he doesn't use it every day. However, I was thinking about trying to find a bulk supplier were I could buy a drum or maybe 100 gal tank to park next to my barn. I was hoping that would be cheaper with bulk rates, and the 5 gallon can is a pain in the butt. I fill that, come back, fill the tractor, and now I have an empty can. Hard to keep an extra 5 gallons on hand like that, and the nearest station with diesel is about 5 miles away. Makes it a real pain if I'm running low and need to mow or do some other project.
Looks like there's some room toward the back of the case. I do plan on doing work in the woods so I want any protection from branches I can get. Maybe I could silicone a piece of aluminum to it just to keep it from getting torn. hmmmmmm....
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
