GC2400 hydraulic issues
   / GC2400 hydraulic issues #1
travelman
Lakeland FL
massey ferguson gc2400 & 1972 model 175
Hi
I have 2009 GC2400 with 229 hours just bought 4' 3pt rotary mower, when using hyd will not hold cutting height mower slowly settles till cutting too low reset mow for a bit same thing, noticed bucket also settles after mowing for a bit have to lift up to clear ground. hyd oil level in window is correct, mower is a light to medium duty so weight should not be a issue. looking for imput as to what might be going on. thanks
   / GC2400 hydraulic issues #2
On the 3PH, don't implements eventually settle "all the way down"? Is there not a way to set minimum height with wheels and/or 3PH linkage adjustment? (I don't know, as I use a belly mower.)
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
377811 (A48836)
377811 (A48836)
2020 JOHN DEERE 7R210 LOT IDENTIFIER 48 (A53084)
2020 JOHN DEERE...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2019 RBR Venturi 380 (A53472)
2019 RBR Venturi...
