Tires GC2310 wheels/tires
   / GC2310 wheels/tires #1
Turfmaster6
Greenfield, MA
Craftsman 1100, MF GC2310
Greetings,
I'm in the process of buying a 400-hr GC2310 from another state that is reputed to be in nice condition. I suspect this will go through smoothly. I'll be adding a mower deck and snowblower once I get it home. This unit is equipped with ag tires and, based upon comments from you guys, R4's sound like the right setup for my property... 75% turf 25% woods. Some questions...
1. Where would I find wheels and tires? I spent an hour searching and came up with nothing.
2. I've got dealers for other brands all around me. The MF guy I trust is 200+ miles away. Is it "polite" to ask a non-MF dealer to mount the tires? To liquid fill them? The old axiom of never piss off the guy who aligns your tires is in the back of my mind as I ask this.
Thank you.
   / GC2310 wheels/tires #2
I took my tires to a John Deere dealer to get them filled with Rimguard. My dealer only had calcium, and I wanted something non corrosive.
   / GC2310 wheels/tires #3
I've got 2 new factory rears (R4) purchased from the MF dealer last fall. I no longer have a use for them. I see you are in MA. $350 shipped to you if interested. IIRC, I paid around $325 for the pair. I had the fronts but ended up using them as they wear alot faster.(
Greetings,
Thank you.
Hey, thank you for getting those on my screen. If I go forward with the R4 plan, will definitely keep it in mind.
   / GC2310 wheels/tires #5
Try the AG tires first, I have them on mine and don't have any problems unless I'm using the diff lock. my father has a Kubota with the R4 and prefers to mow his steep places with mine because of the extra traction. Don't rule them out so quickly.
Rich
   / GC2310 wheels/tires #6
Rich
Well said Rich. If you have steep hills, keep them. I don't have too much of a problem with tearing up my lawn and I use it weekly. It will, if you use diff lock and try to turn though.
:2cents:
   / GC2310 wheels/tires #7
I've had ag's on mine from day one, no regrets.
I don't use the 2410 to mow, but still run on this lawn without issue, as long as I don't regularly use the same path. If I do that, I doubt it would matter what kind of tires I had, the weight of the machine will kill the grass, at least temporarily.
The lawn isn't the greatest, but it's covering a rock pile.
The spot where the first picture was taken is in the foreground.
Good advice guys... I've made a few passes over the lawn with the new tires with no issues. The ag tires will remain. Until you get experience, it's hard to weight the accuracy of everything you read:)
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52748)
Michelin CARGOXBIB...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
Hyster H225E (A47384)
2017 Ford F-150 XL (A50120)
2017 Ford F-150 XL...
Safety Basket (A50121)
2022 Aluma 7712H Tilt Trailer (A50515)
2022 Aluma 7712H...
