GC2310 Loader Joystick Stiff
   / GC2310 Loader Joystick Stiff #1
madhatter
Sherwood Park,Alberta,Canada
2015 Massey GC1710
Recently my loader GC2310 joystick when cold, is stiff when raising or lowering. After I work it a bit it loosens up and is normal. I store it in doors when not in use so the elements is not an issue. I lubed the knuckles so that is also not an issue. Any thoughts ? :confused:
   / GC2310 Loader Joystick Stiff #2
Maybe , just maybe the viscocity of your hydraulic is too heavey causing the oil to have to warm up before it flows easy. Just thinking out loud ............:confused::thumbsup:
Just started doing and the Amsoil hydraulic fluid is what I have been using all along. Maybe the spool needs cleaning/greasing, but I don't see how it would get gunked up as it has a cover over it....
   / GC2310 Loader Joystick Stiff #4
My GC 2400 has cables that connect the stick to the valve block. I am sure that your GC 2310 has the same setup. take the plastic cover off of the bottom of the joy stick and lube the cables.
The GC2310 joystick is setup a bit differently. I took the spool apart and it was clean and well lubed. Relubed and re-assembled. Seems ok now for some odd reason.
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
2019 TAKEUCHI TL6R SKID STEER (A51246)
2019 TAKEUCHI TL6R...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A51247)
2000 TRAILKING...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
TOSHIBA 8000 BTU WINDOW AC UNIT (A51248)
TOSHIBA 8000 BTU...
