GC2310 Loader Joystick Stiff
   / GC2310 Loader Joystick Stiff #1
madhatter
Sherwood Park,Alberta,Canada
2015 Massey GC1710
Recently my loader GC2310 joystick when cold, is stiff when raising or lowering. After I work it a bit it loosens up and is normal. I store it in doors when not in use so the elements is not an issue. I lubed the knuckles so that is also not an issue. Any thoughts ? :confused:
   / GC2310 Loader Joystick Stiff #2
Maybe , just maybe the viscocity of your hydraulic is too heavey causing the oil to have to warm up before it flows easy. Just thinking out loud ............:confused::thumbsup:
Just started doing and the Amsoil hydraulic fluid is what I have been using all along. Maybe the spool needs cleaning/greasing, but I don't see how it would get gunked up as it has a cover over it....
   / GC2310 Loader Joystick Stiff #4
My GC 2400 has cables that connect the stick to the valve block. I am sure that your GC 2310 has the same setup. take the plastic cover off of the bottom of the joy stick and lube the cables.
The GC2310 joystick is setup a bit differently. I took the spool apart and it was clean and well lubed. Relubed and re-assembled. Seems ok now for some odd reason.
(APPROX 24) 2" X 6" X 60" CHANNEL IRON (A51247)
(APPROX 24) 2" X...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2017 GENIE S-60X MANLIFT (A51246)
2017 GENIE S-60X...
10x16.5 Tire Assembly (A53472)
10x16.5 Tire...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
