GC2310, blown fuse .
   / GC2310, blown fuse . #1
plowking
Nottingham, N.H.
2009 MF 1531 TLB
My wife was using tractor and the backhoe, she had to move seat a lot. At the end of day, the tractor stalled and wouldn't click or start. I called the dealer and he had me check the fuses, the 10 amp was blown. They said if the harness to safety switch gets pinched and damages wire [ no wire was exposed at the kink and wasn't touching] it can cause a fuse to blow. I am thinking of changing the wire to a heavier gauge, so it won't be as easy to kink as original wire is real thin. On a different subject ,my dealer sent me a letter with coupons, discount on parts and service and they are going to free pickup of tractor versus a 130.00 pickup/ delivery charge. plowking
   / GC2310, blown fuse . #2
Nice dealer!!! I didn't get any free cuopons - but, I am still happy with the deal I got for my GC2300. And, I like my dealer.
But, I sure would have liked the packet of coupons.:(
   / GC2310, blown fuse . #3
If it is a single wire, run it through a vacuum hose or silicone aquarium tubing. That will protect it and also keep it from from kinking. If you can't get it through because of the end connector, there is a easy way to make a splitter for the hose. Drill a hold about a 1/16" larger than the hose in a piece of 1/2" wood. Then take a single sided razor blade and drive it into the wood. The razor blade will need to be about half way into the hole. Cut the end of the tubing about a quarter inch or a little more, then put it into the hole and start pulling. Makes a really nice wire protector.
   / GC2310, blown fuse . #4
Good old Northwood Power and Eq. I got the same coupons as well.
   / GC2310, blown fuse . #5
Phillips Wire Company makes a Single wire split loom it is plastic with ribs and has a slit running the length of the loom. This is good because you do not have to disconnect the wire to install it. Hope this helps good luck.
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
2015 Ford Econoline Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A52748)
New Lewis Brothers...
New Holland 479 Haybine (A50774)
New Holland 479...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
