GC2310 backhoe dipper lever won't center
   / GC2310 backhoe dipper lever won't center #1
crazyjncsu
Cleveland, OH
MF GC2310
Video here (1:42):
GC231 dipper lever won't center - YouTube
The dipper level won't center when moving one direction (it centers back from the other direction) ... Also when moving in the bad direction, it moves past the range where it activates the dipper to the point where it stops moving the dipper. Make sense?
Valve assembly here:
AGCO Parts Books (SL158419)
Where do I start fixing this thing? Thanks!
   / GC2310 backhoe dipper lever won't center #2
Never had to rip one apart yet. A lot of GC backhoe owners on this site.
   / GC2310 backhoe dipper lever won't center #3
My guess is, there are internal springs that center it.
And, one is broken?
I wouldn't take the vale apart without a diagram. There may be things like small check balls, and springs, that like to escape.
   / GC2310 backhoe dipper lever won't center #4
Sure does sound like there's something loose in there- mine makes no "clicking" noises like yours at all. I have also never had to take mine apart. Let us know what you find!
   / GC2310 backhoe dipper lever won't center #5
Just a thought, crazy-- are those ball & socket linkages worn out, maybe allowing too much play/sloppiness?
Turns out it was the "positioner" ... Tried to fix the part myself, but no go. Took 4 months to get it from jacks as it was on factory back order.
Easy fix though; its external to the valve.
   / GC2310 backhoe dipper lever won't center #7
Thanks for the follow-up!
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
2025 Quality Steel 6' x 14' Utility Trailer (A50515)
2025 Quality Steel...
2012 Case 850L XLT Dozer (RIDE AND DRIVE) (A50774)
2012 Case 850L XLT...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400LB 3 Ton Crane Service Truck (A50323)
2014 Ford F-550...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
