GC2300 stalled climbing a hill
   / GC2300 stalled climbing a hill #1
JDKu
Bronze Member
Calgary, Alberta, Canada
GC2300
I was mowing up a steep ditch, and the tractor died on me. I let it coast back down the hill, fired it up, and then proceeded to climb again. Once again, it started to sputter, so I backed down the hill as quick as I could, and managed to keep it running.
Please note, the tractor did not power out.
Any thoughts on what it could be? I thought it might be the seat switch, so I was "bouncing" on the seat the 2nd time trying to make sure there was good contact. It didn't seem to help.
I had over a half a tank of diesel, so the tractor shouldn't have been starving.
The hill is steep enough that I can't climb it in 2WD, but it really isn't that steep. I'm pretty certain I could mow across it sideways. I used to with my JD L-120. The GC2300 seems to have a higher center of gravity, and I haven't braved going sideways on this hill yet.
I went up this hill a number of other times during the day, but I went up it really quick so as not to spend more than 5 or 10 seconds on it. No problems then.
Any thoughts on what happened?
   / GC2300 stalled climbing a hill #2
I would top off the fuel and try it again. I have a very steep road back and my 2610 will sputter in it not completely full of fuel.
   / GC2300 stalled climbing a hill #3
You might want to look at the fuel sediment bowl. If it is low, then it quite likely the fuel/lift pump is starving out and/or going bad. My Yanmar did that when it was going be, and it actually took a year before it became obvious.
My GC2400 routinely does hills (up and sown) and never starves/stalls. You were in low on the HST?
   / GC2300 stalled climbing a hill #4
I would do that...mine died this weekend with 1/2 tank in the same situation. Filled it up, fired it up and mowed all day no other problems.
   / GC2300 stalled climbing a hill #5
my jd990 would and has died at 1/2 tank ,so i always top it off.
   / GC2300 stalled climbing a hill #6
It wasn't a situation where you leaned forward --a natural reaction-- when going uphill? My seat switch will occasionally remind me to put my butt back on the seat!:laughing:
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
Woods 7200 3 pt Finish Mower (A50514)
Woods 7200 3 pt...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
Kinze 600 Grain Cart (A52349)
Kinze 600 Grain...
TMA (A49461)
TMA (A49461)
