GC2300 Snow-blower
/ GC2300 Snow-blower #1
67PLY
PENNSYLVANIA
MASSEY GC2310
We have a 2005 GC2310 TLB - our local John Deere dealer has a GC2300 with loader - mower and a snowblower (took in on a trade) ..... I was going to try to buy just the 'snow blower' - looks like it wasn't used much. What would be a fair offer - in the hot month of July ??????? Thanks.
/ GC2300 Snow-blower #2
I paid $2900.00 for the blower and the front quick hitch(which you must have) for mine brand new. I would offer 50% of that as a starting point.
Don - Did you buy your tractor at Lincoln Supply in Somerset ? We did in 2006 - seeing a few like this one traded in on a JD makes me wonder if it was traded because lack of dealer in the Johnstown/Somerset area. Do these snowblowers work well in wet snow ?
/ GC2300 Snow-blower #4
The one that I have with my 2410 works great in wet or dry snow.
/ GC2300 Snow-blower #6
Negative. I purchased mine in Bruceton Mills, Wv. . They are 13 miles from my house.
I can't give a lot of info about the snowblower, as I've only used it twice since I purchased it, and neither time was really necessary. I did it because I could.
Sometimes we get 'lake effect snows' that can easily dump 3ft or more on us in a single night. I was willing to spend the extra $2900, just for the peace of mind.
/ GC2300 Snow-blower #7
I just realized that in post #2, the words "quick hitch" showed up as an embedded link on my computer. If it showed up on anyone else's that way, I did not put that there. And that is not the hitch required for the front mount blower on the Massey GC series.
Don - I looked at the used 2360 blower again today. Looks likes all parts are there - midmount shaft - short blower shaft - front mount with lift cylinder and hoses - chute with hand crank. All moving parts are well greased. What make are your plow and cultivator ?
/ GC2300 Snow-blower #9
Ditto on the blower... I ordered my 2310 with the blower back in 2007. Never regretted it. Dry snow = about 60' throw(!), wet stuff reduced by from 30 to 50%, depending on how wet it is. REALLY wet stuff will sometimes clog the chute, but I've only had that problem a few times... and I'm talkin' "water-dripping-out-of-the-snow" kind of wet.
Only issue I've had with mine is bending the tips of the impeller blades from picking up rocks; that will reduce the throw, but a body-shop dolly and a hammer can bring it back up to snuff, pretty much.
If necessary, you can also leave the quick-hitch on (but be careful, as it hangs down pretty low) and swap from blower to FEL in about 5 minutes.
And, as Will said, they're built quite well- very rugged, quality stuff. You can probably tell that I love that blower! :cool2:
Walt/irvingj
I made them a fair offer on the blower - should know by the end of the week. My drive is paved - so no rock throwing. Noticed metal wire inside the chute - what is that for ?
Dealer wants $ 1500.00 for the blower and all the stuff that goes with it. Good price ????
/ GC2300 Snow-blower #13
That's to keep rocks from flying through the air like a missile, and to keep you from putting your hand down the chute. That was also what I removed from mine because it's just ripe for clogging the chute.
Thanks for all the input. How much does weigh?
/ GC2300 Snow-blower #16
I just checked my manuals, and no weights are listed for the blower or the hitch. And there are seperate manuals for each.
/ GC2300 Snow-blower #17
$1500?? You bet that's a good price! Seems to me as an add-on option when new it was pushing $3000, with all the parts.
As far as weight, I'd guess mine is as follows:
1) Quick-hitch assy...... approx. 70 lbs
2) Blower itself (mine has electric controls)... approx. 165 lbs
3) Mid-PTO driveshaft, 36" +/-..... approx. 12 lbs
Guess that adds up to about 250 lbs all together. Sounds light, but that's my guess... and that's what it is, a guess.
As far as that wire thing on the chute... well, let's just say mine didn't last long either! :laughing:
WBB/irvingj
Got the blower and a used Honda 4213 riding mower (didn't run) for $ 1500.00. Honda mower had a broken wire to fuse box - fixed that Runs and mows great. The same JD dealer had a Kubota BX2750C blower also ...... identical to the MF 2360 except orange.
/ GC2300 Snow-blower #19
Yep, I'd say you can call that a deal!!
Gave the mower to a freind that needed one. When it comes time - will be asking how to attach front quick hitch to tractor. Thanks.
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2016 Deere 550K (A64126)
2016 Deere 550K...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
