GC2300 Rocks!
/ GC2300 Rocks! #1
JDKu
Calgary, Alberta, Canada
GC2300
I was impressed with the size of rock the GC2300 was able to pick up. So I took a few picture just in case anyone else wonders.
The hydraulics creep quite a bit. Perhaps every minute I had to adjust the tilt on the bucket, and every 3 or 4 minutes, had to lift the arms again. Is that normal for this tractor (I'm new to it). Same for 3 pth. Or did I buy a tractor that has more than typical wear on it? Around 380 hours on it.
Chris
/ GC2300 Rocks! #2
Nice Rock! Heck, she can handle a bigger one that that. This one was a bit of a struggle with all that weight out front.
/ GC2300 Rocks! #3
I've used mine for digging rocks started last fall digging the rocks and have most of them done now only problem's I've had so far is blew 2 hydralic lines so far,the lines aren't that good there only rated for 3000psi should have 5000psi lines on them.Larry
/ GC2300 Rocks!
Do the hydraulics on your tractors creep?
Just curious what is normal for these little guys.
Chris
/ GC2300 Rocks! #5
Chris
Yes, and it is not uncommon.
Pushing your luck doing this kind of stuff, you will likely increase the amount of leakage. :eek:
/ GC2300 Rocks! #6
Chris
You might want to keep an eye on those hoses on the joystick valve bank...especially if you're pushing the limits...they are pointing right at your face and the factory hoses are junk. I've replaced all of my hoses with Dayco and also placed protective sleeving over any potential trouble spots (to protect me, not the hoses).
/ GC2300 Rocks! #7
One problem is, some people are surely going far beyond the original intended design/purpose for these.
I have not had to replace any hoses....yet. But, I don't really try to find out what the failure point is when I use it.
Sally's dad: How much did a full set of Dayco hoses cost?
/ GC2300 Rocks! #8
Some of the rocks in the photos would definitely have my relief valve screaming...I don't take it that far. The problem with the hoses on mine were more related to UV degradation instead of abuse...tractor spends a lot of time mowing in the summer months using the MMM and a Swisher 60" offset maintaining about 5-6 of my 25 acres (the rest is wooded and pature/hayfields). I'm not sure of the total cost to replace all of the hoses at one time as I replaced most one at a time when they began showing degradation signs and I reached a point where I no longer trusted them...they are expensive...I've been paying $3.19 p/ft. for Dayco E-Z Flex 1/4" I.D. 5,000 PSI...the O.D. is slightly larger and have a much higher quality jacket. Crimped on JIC's are $4.27 each and crimped on FIP's are $3.79 each. I'm basing this on the last receipt I found for a 4' hose which had an itemized breakdown. I can tell you that Dayco hoses I installed 5 years ago still look new (when clean, of course). The steep bend near the fittings on the loader valve are especially vulnerable. Anywhere the factory hoses where protected from sunlight still looked pretty good, unfortunately most of them terminated outside on the tractor or loader boom at some point and the jackets were becoming brittle, so eventually all were changed out. My tractor is stored inside but spends a lot of time working outdoors. First year I had it (2004) I used it to excavate, dig footers and put in drainage for a new shop (36' x 42') and also added another 2 car garage behind the house for the boat and one of my old Fords (28' x 32'), so it spends it fair amount of time outdoors.
/ GC2300 Rocks!
I also have a Swisher 60" and a mmm on the GC2300. I'm looking forward to cutting!
Chris
/ GC2300 Rocks! #10
The heavier the weight and the hotter the oil the faster the creep. It's normal.
DEWFPO
/ GC2300 Rocks! #11
I would just dig a hole next to the rock deeper and roll it in and bury it. Or just get a bigger machine to lift something that big.
/ GC2300 Rocks! #12
I'm guessing you have never tried to dig a hole in new england? Those rocks in the pics are the little ones. Digging a bigger, deeper hole only leads to one thing... More and Bigger rocks :laughing:
I like the bigger machine option:thumbsup:, unfortunately the wallet does not always agree.
/ GC2300 Rocks! #13
When reading Wacky's post, the same thing occurred to me! :laughing: Dig a hole around here, and you're likely to find MORE rocks.... or ledge!
/ GC2300 Rocks! #14
Having been a farm boy here in New England I can say the first crop each year is ROCK!:laughing: For thoes no from here that is why we have so many stone walls :D
/ GC2300 Rocks! #15
I remember it well having lived in Connecticut as a kid and with names like Stonington! I chipped a tooth on one of those rocks as well!:(
/ GC2300 Rocks! #16
I did get lucky a couple of times, and only have to remove two, or three smaller rocks to make room to bury a larger one deeper.
2020 Elgin Pelican Street Sweeper (A64194)
2020 Elgin Pelican...
2022 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2022 GMC Sierra...
2017 Hino 155 16ft. Box Truck (A64556)
2017 Hino 155...
Groundsmaster Mower (A64194)
Groundsmaster...
10000LBS Two Post Automotive lift (A64194)
10000LBS Two Post...
2020 CASE TV450B SKID STEER (A65053)
2020 CASE TV450B...
