GC2300 Replacement Seat
/ GC2300 Replacement Seat #1
vicos
Has anyone found a suitable aftermarket replacement seat for a GC2300 (MF P/N: 3605906M92)?
Paying $329 for a replacement is bad enough, but I do not want to buy another seat that is going to fail just like the first one did.
This guy on eBay is selling a K & M Unibody Professional Seat, Model# 7781, with his own bracket added to fit the GC2300 (Massey Ferguson Seat GC2300 GC2310 3605906M92 | eBay). Problem is that he wants $179 for a seat that Northern is asking $110 (K & M Unibody Professional Seat, Model# 7781 | Forklift + Material Handling Seats | Northern Tool + Equipment)
I called the K&M factory and they do not offer a direct replacement for the GC2300, although he was shocked at the price the guy was asking on eBay.
I'm not a metal fabricator, so any extensive bending or welding is not an option.
/ GC2300 Replacement Seat #2
I have done this type of job in the past on other tractors. I believe all you would need is to make like a 10ga. plate that has a set of holes to match both the seat, and the mounting rails on the tractor. Attach it to both, and your done.
You could probably get a local fabricator to cut it to size, then all you would need is a drill, and some paint.
/ GC2300 Replacement Seat #3
Are you sure that your current seat bracket can not be bolted directly onto the 7781 seat without much modification. There is a bolt pattern on the K & M web site and it appears there are additional mounting options from the picture posted on Ebay. Either way the brackets used by the Ebay seller are not worth 69$.
Doug
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
INTERNATIONAL 700 SERIES 6 BOTTOM PLOW (A64278)
INTERNATIONAL 700...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
Craftsman 16in Variable Speed Scroll Saw (A64553)
Craftsman 16in...
2015 International WorkStar 7500 T/A Forestry Grapple Truck (A64556)
2015 International...
