GC2300 Replacement Seat
   / GC2300 Replacement Seat #1
vicos
Has anyone found a suitable aftermarket replacement seat for a GC2300 (MF P/N: 3605906M92)?
Paying $329 for a replacement is bad enough, but I do not want to buy another seat that is going to fail just like the first one did.
This guy on eBay is selling a K & M Unibody Professional Seat, Model# 7781, with his own bracket added to fit the GC2300 (Massey Ferguson Seat GC2300 GC2310 3605906M92 | eBay). Problem is that he wants $179 for a seat that Northern is asking $110 (K & M Unibody Professional Seat, Model# 7781 | Forklift + Material Handling Seats | Northern Tool + Equipment)
I called the K&M factory and they do not offer a direct replacement for the GC2300, although he was shocked at the price the guy was asking on eBay.
I'm not a metal fabricator, so any extensive bending or welding is not an option.
   / GC2300 Replacement Seat #2
I have done this type of job in the past on other tractors. I believe all you would need is to make like a 10ga. plate that has a set of holes to match both the seat, and the mounting rails on the tractor. Attach it to both, and your done.
You could probably get a local fabricator to cut it to size, then all you would need is a drill, and some paint.
   / GC2300 Replacement Seat #3
Are you sure that your current seat bracket can not be bolted directly onto the 7781 seat without much modification. There is a bolt pattern on the K & M web site and it appears there are additional mounting options from the picture posted on Ebay. Either way the brackets used by the Ebay seller are not worth 69$.
Doug
43018 (A51691)
43018 (A51691)
2018 Ram 3500 Reading Service Truck with Liftgate (A50323)
2018 Ram 3500...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
Kivel Q.A Pallet Forks (A50121)
Kivel Q.A Pallet...
DMI 13' Chisel Plow (A50515)
DMI 13' Chisel...
