GC2300 rear blade
   / GC2300 rear blade #1
Chiege
SE Ohio
MF GC 2300
Hi all,
Looking at a Midwest brand 60" (RB22) blade fro my GC2300. Need for snow/gravel in driveway, as well as cutting bench cuts in hills for a jogging trail in my woods.
Any thoughts or recommendations?
Thanks,
   / GC2300 rear blade #2
Chiege, Well it looks as if it does it all tilt,angle, slides.....Seems that it would do the gravel & snow well, It probaably will do the other tasks mentioned but not as good as a loader.... Just take longer , Look at it this way more seat time /forums/images/graemlins/cool.gif
If the price is right , and the color is red ,you decide /forums/images/graemlins/grin.gif
I assume you don't have a loader...
You will probably find that you won't use the tilt or the slide part much...So why pay for it, For general blade work you could check King kutter if its in your area, There fairly reasonable as well and pretty durable depending on if you use or abuse your equipment.... Question how do you like the 20 series blade from midwest? That might just be what you need ,unless you have some sharp grading to do then I would consider the 22 series /forums/images/graemlins/cool.gif something to think about.
Been wondering where you've been ,haven't post in a while. /forums/images/graemlins/smile.gif
   / GC2300 rear blade
Hello Nasty,
I do have a FEL, my bio was supposed to have that, but it must have gotten erased. Anyway, I think a tooth bar will be in my future.
I still want a back blade with tilt and all of the features. It will help in some ways that my loader won't. It will also be much needed weight on the rear. My land is typical for SE Ohio -HILLS (That's why the tilt will come in handy).
I appreciate your thoughts.
You are right I haven't posted in a long time, but I look at the forums every day. Always lurking in the background.
<font color="green"> </font>
   / GC2300 rear blade #4
I put a Kioti RB22-60 rear blade on my Kubota BX23 and I think it works great. The Kioti RB22-60 is made by Midwest for Kioti - only reason I got the Kioti instead of the Midwest is because I wanted one in orange to match the tractor. The one problem I did have however is that that the 3pt on the BX would not lift the blade high enough to get it off the ground - I had to make some custom lower brackets to lower the mounting point and then redrill the upper 3pt mount frame to lower that mounting point and then the BX 3pt lifted the blade more than high enough. Since the GC2300 3pt probably has pretty much the same lifting capacity as the BX 3pt you might also have to do this mod. Even with having to do this mod I would highly recommend the Midwest blade - because it has the swivel, tilt, and offset - and also because after looking at a bunch of rear blades I think it has the best combination of features, is the best built, and it is also one of the heavier blades in this size. I will post some pictures of my blade mods so you can see how it worked.
   / GC2300 rear blade #5
another shot
   / GC2300 rear blade #6
and another
   / GC2300 rear blade #7
one more
   / GC2300 rear blade #8
picture of blade on tractor with plenty of snow
2015 Ford Transit 350HD Passenger Van (A50323)
2015 Ford Transit...
New Holland 479 Haybine (A50774)
New Holland 479...
Danuser Digger F-8 (A52748)
Danuser Digger F-8...
1986 John Deere 6359D (A50121)
1986 John Deere...
Welder (A50121)
Welder (A50121)
2006 Komatsu PC400LC Hydraulic Excavator (A50322)
2006 Komatsu...
