GC2300 improved hydraulic pump shaft part number??
   / GC2300 improved hydraulic pump shaft part number?? #1
dragula
Finally disassembled the 2310TLB to discover that my pump shaft and gear is sheared as suspected.
I have searched for an hour and can not find the part number for the new longer pump shaft. I have the part number for the gear. I thought I had found the part number for the shaft a while back so that I didn稚 have to replace the entire pump.
Does anyone know what the part number for the new longer shaft is? Just the shaft only.
Thanks!
   / GC2300 improved hydraulic pump shaft part number?? #2
I would be surprised if they don't make you buy the whole pump.
You may be right. I found the part number for the whole pump but I can稚 tell if has the extended shaft or not. This is very frustrating.
   / GC2300 improved hydraulic pump shaft part number?? #4
I would expect they only sell the newer version.
   / GC2300 improved hydraulic pump shaft part number?? #5
Yes I think the part was was revised but not sue.
   / GC2300 improved hydraulic pump shaft part number?? #6
Thanks!
I've been researching this same issue and on another thread he used crii.net kp05106csss pump. Don't know if you can just replace the shaft. Here is the thread. GC2310 Wrong Pump installed He shows pictures of the difference in the shaft. Curious as to what you finally ended up doing?
   / GC2300 improved hydraulic pump shaft part number?? #7
Try sending him a PM private message. That would get you in his E-mail.
Click on the D above his name.
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2020 GMC 2500 HD (A50120)
2020 GMC 2500 HD...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2019 Dodge Journey GT SUV (A50324)
2019 Dodge Journey...
Skid Steer (A51691)
Skid Steer (A51691)
HD Bin Dump Forks (A50120)
HD Bin Dump Forks...
