GC2300 hydraulic service
   / GC2300 hydraulic service #1
mewaschuk
VT
GC2300
Trying to change the hydro fluid in my GC2300 but when i pull the drain plug (lower bolt near filter) and the filter no oil comes out. Fill plug is removed too. Any suggestions? 🤔
   / GC2300 hydraulic service #2
The drain plug in near the back of the oil pan under the right axle. Are you cleaning the suction screen as well?
Prob but didn稚 pull wheel. So drain is not the bolt right next to the filter? 2 bolts right next to each other. Thx.
   / GC2300 hydraulic service #4
The 2 bolts next to the filter are referred to as "plugs" in the schematics. Probably holes left from the casting/machining of the HST housing.
   / GC2300 hydraulic service #5
There are some similar size bolts going into the transmission from the side that hold the right-hand axle cover to the case.
The drain plug is inserted vertically into the bottom of the right axle cover about 3-4 inches from the filter. Number "4" on the picture.
The suction pickup is on the left side of the transmission case, with a hose leading from it. There is a banjo fitting with two O-rings and a wire mesh screen on it to filter out particles from the hydraulic fluid.
-Phil
-Phil
Big thanks !!!
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
John Deere 6120E (A50323)
John Deere 6120E...
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
John Deere L118 Automatic 42in Riding Mower (A51694)
John Deere L118...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
