Oil & Fuel GC2300 -Hydraulic Oil plug
   / GC2300 -Hydraulic Oil plug #1
Chandra Sharma
BRIDGEMAN DOWNS, QUEENSLAND AUSTRALIA
MF GC2300
INTERNAL THREAD FOR THE HYDRAILIC OIL PLUG HAS SHEARED. I AM LOOKING TO INSERT A TREAD COIL AND USE THE SAME PLUG. COULD SOMEONE ASSIST WITH THE SIZE OF THE THREAD ? IS THIS METRIC ?
cHANDRA
   / GC2300 -Hydraulic Oil plug #2
Assuming you're talking about the transmission drain plug, I can't help you-- no indication of size in owner's manual or service manual, except for my own notation of using a 19mm wrench on the plug-- which is also a 3/4" wrench size, so that doesn't help....
Bolts & such on the tractor are said to be metric, but I've a feeling that not all are. I think you're going to have to contact the dealer on that one. Sorry!
   / GC2300 -Hydraulic Oil plug #3
cHANDRA
If It was me ?? I'd get a standard tap just a bit bigger then the old hole and rethread it for a bit larger plug.Being it Aluminum or cast won't make any difference.Just make sure you have enough heavy material around the plug hole to do this.Shouldn't be too big of a problem. :thumbsup:Larry
thanks for your assistance so far. I have a parts manual for this tractor, and suprisingly the tread size for the engine sump plug is noted as 1.5 but there is no mention of the size on the transmission plug. I am just wondering if the size is the same
Chandra
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52748)
Texas Post Driver...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A52748)
2012 NEW HOLLAND...
