GC2300 Hydraulic Leak- Left side
   / GC2300 Hydraulic Leak- Left side #1
DaleH
Hi all. Just a quick enquiry. I was just about to switch our 6 year old GC2300 FEL to the snow thrower for the winter. In the near dark, I could see hydraulic fluid running (as opposed to dripping) from some place above the left side rear wheel drive shaft, too dark to see exactly where. It seemed quite high up as it was running down the left side as well as the front near the hydraulic filter. No known damage or anything comes to mind but it has been very dusty/dry so I was wondering of a plugged vent or accumulated debris somewhere was causing the fluid to vent out?
Just wondering if this might ring some bells with the more experienced guys here before I can get it into the garage to get a better look.
Thanks for sharing any thoughts.
   / GC2300 Hydraulic Leak- Left side #2
Could be a loose hose or fitting under the seat or even a split hose.:confused:
   / GC2300 Hydraulic Leak- Left side #3
That is a new one.
But, there are hoses behind the seat, up near the top of the transmission housing that could potentially be leaking.
That is a new one.
Thanks. At least I know where to start looking now. I'll report back later.
   / GC2300 Hydraulic Leak- Left side #5
One of the two hydraulic hoses I've had to replace was one that went all the way from the front to the back. Seems like it was in the area you're talking about. (Not sure because it was a couple years ago....) WBB
Well, I've had a look at the problem. When I started her up to put her into my heated garage there didn't seem to be any leakage at all. However, once I got some lights on the area I could see a bit of oil way up just below the fuel tank. Just to see where the oil was coming from I cycled the 3 pt hitch lever. This started a huge gush of foamed up oil from somewhere higher up somewhere out of sight under the fuel tank.
After contemplating what it would take to get at that area, I've decided to have it taken into the dealership for repair.
Thanks for the responses, guys.
Dale
   / GC2300 Hydraulic Leak- Left side #7
Please let us know what they find.
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2013 New Holland BR7060 (A50123)
2013 New Holland...
TORO Z MASTER 4000 PRO HDX ZERO TURN MOWER (A51247)
TORO Z MASTER 4000...
2024 Dig Master DM-F20 Electric Fork Lift, NEW! (A52384)
2024 Dig Master...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2015 Ford F-450 Flatbed Truck (A51691)
2015 Ford F-450...
