GC2300 Hydraulic Filter Plug (HST Housing System)
   / GC2300 Hydraulic Filter Plug (HST Housing System) #1
Chandra Sharma
BRIDGEMAN DOWNS, QUEENSLAND AUSTRALIA
MF GC2300
I have accidently broken the housing that holds the hydraulic filter . Can any one please advise what would be the best way to fix this without changing the entire housing cover ( cost approx $ 500 )
Chandra
To who it may interest
AFTER ADVISE FROM VARIOUS LOCAL AMATEURS I MANAGED TO PROGRESS REPAIRS WITHOUT HAVING TO TAKE THE COVER OFF .THE HOUSING FOR THE FILTER IS M20 TREAD WITH 1.5MM PITCH WHICH IS MACHINED IN COVER BODY. THE COST OF REPAIRS ARE LIKELY TO MOUNT TO ABOUT $1500 ( INCLUDING LABOUR AND PARTS)IF I HAD TO REPLACE THE COVER FOR A NEW ONE . HOWEVER I HAVE SEEN MANY LEAKING HYDRAULICS ONCE THEY ARE OPENED UP FOR REPAIRS AND REFITTED. HENCE I THOUGHT OF TRYING THIS AND IT WORKED PERFECTLY.
THERE 1S AROUND 24MM OF FAT IN THE BODY WHERE THE OLD FILTER HOUSING WAS. THE WIDTH OF THE HOLE ON THE HOUSING TO THE FILTER IS APPROX 10.5MM .I BOUGHT A BOLT ( STAINLESS STEEL) WITH A M20 THREAD ,DRILLED A 10.5 MM HOLE , STEPPED THE TREAD DOWN TO 18MM ON THE END THAT WAS LATER TO BE THREADED INTO THE BODY. WIDENED THE HOLE IN THE BODY OF THE COVER FROM 10.5 TO 16.5 WITH A 16.5 MM BIT FITTED TO A 18V DRILL ( FULL CHARGE). WITH A M18 BY 1.5 PITCH TAP , THREADED THE HOLE IN THE BODY FOR 12MM (LENGTH). HAD TO BUY A 15MM MAGNETIC LEVEL TO ENSURE THAT DRILLING WAS STRAIGHT, BOTH VERTICLE AND HOLIZONTAL....I GATHERED A LOT OF COURAGE TO DO THIS AND THE RISK PAID OFF. BEFORE TIGHTENING THE THREADED PORTION OF THE BOLT INTO THE BODY , I HAD CUT AROUND 80% OF THE BOLT HEAD SO THAT ONCE I HAD TIGHTENED THE BOLT IN PLACE, THE HEAD WAS EASILY CUT WITH A HACKSAW BLADE AND SMOOTHED WITH SAND PAPER.
THE JOB IS VERY FINE AND DELICATE AND USE OF VERNIER CALIPER FOR MEASUREMENT IS PARAMOUNT.
IN TOTAL INCLUDING OIL AND NEW FILTER , THE JOB COST ME $200 AND A FEW PARTIAL SLEEPLESS NIGHTS.
CHANDRA
   / GC2300 Hydraulic Filter Plug (HST Housing System) #3
Sorry, no one saw your question.
Had you posted this in the Massey Ferguson Forum instead of here, we could have helped with this.
Basically, the fix is similar to what you did. Kubota makes a repair kit that can be installed easily in the GC housing. Part number 15241-32290.
If you use the TBN search feature, you can almost always find a thread about any issues with these machines, including this one. If not, post your question in the MF forum, and we will help all we can.
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A52472)
2018 WACKER NEUSON...
Vintage Signs (A50324)
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
Coats CHD-9551 Tire Charger (A50121)
Coats CHD-9551...
2014 Kubota RTV1140 CPX (A50121)
2014 Kubota...
