GC2300 - Got Float?
   / GC2300 - Got Float? #2
If the FEL is Model 2350, it has float.
Great news for me, it is a 2350. How do you engage float?
   / GC2300 - Got Float? #4
After lowering the FEL, move the joystick forward past the stop and then let go.
   / GC2300 - Got Float? #5
I pretty much do this, except I push the joystick all the way up before lowering the bucket. I think there was at least one thread fairly recenty about reaching the float position with the joystick. From that thread, most setups seem to be about the same. Skivt, you might try a search through the archives. The latest thread was pretty recent.
   / GC2300 - Got Float? #6
I have a "new to me" 2004 GC2310 with a 2350 FEL and it seems to me that there is not a float position on the joystick. Is this something they changed/improved for 2005? Is there a way to enable or disable the float option on the joystick? If I move the joystick all the way forward it just lowers the bucket and then picks up the front of the tractor. No click or pop of the joystick is felt and I was pushing pretty hard.
Thanks in advance for any help or advice!
   / GC2300 - Got Float? #7
The "float" position is not new. My 2300 is a couple years old and to engage float, the joystick is pushed up all the way. You can feel a "click" when you get to the float position.
I have a toothbar on my FEL that makes an excellent rake when the bucket is turned down the FEL is in float mode.
   / GC2300 - Got Float? #8
Thanks for the info loulblades. It seems to be the consensus so far that all 2350 FEL's can float. My father’s JD has a bucket with the float option and I am familiar with the feel of the "click." My 2350 FEL has no such "click" and I am talking with the dealer now to see if it may be broken, or if it can be updated. I can not think of any other reason why it will not float? Could it have something to do with the hydraulic lines?? Maybe I will try removing the rubber boot tonight to see what is inside.....
I agree completely that the float option is a great feature to have and there are many applications I could use it for.
And I also plan on getting a toothbar based on everyone’s enthusiastic reviews....
Thanks again!
   / GC2300 - Got Float? #9
Float is a function of the valve spool. When the spool is in the float detent position, hydraulic fluid from both sides of the cylinder are directed to tank, in other words, both work ports for that spool are connected to the tank outlet of the valve. The FEL should then "float" because there is no hydraulic pressure on its cylinders. If the spool detent is not functioning you may only get it into float by manually holding the lever in what would be the spool's float position.
   / GC2300 - Got Float? #10
Does the 2350 have a plastic housing over the valve? On my 1531 that housing was interfering with the ability to work the curl cylinders while floating. Maybe yours is preventing it from engaging float at all. Look in my gallery for pics.
1997 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1997 HEIL TRAILER...
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
Toro Workman Utility Cart (A51694)
Toro Workman...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
Toro Mower (A50324)
Toro Mower (A50324)
