Oil & Fuel GC2300/GC2310 transmission/hydraulic oil level
   / GC2300/GC2310 transmission/hydraulic oil level #1
FredWalter
Southwestern Ontario, Canada
John Deere 5300, Gravely 8163G, BCS735, etc
The GC2300/GC2310 Operator Instruction Book says "Oil should be visible in the oil level window".
I have oil visible, up to about half-way in the window. Is this enough? Or does "be visible" mean the entire window should have oil visible in it?
(I lost a bit of oil when a I damaged a hose, and I'm wondering if I need to put more oil in, or if I have enough in there.)
   / GC2300/GC2310 transmission/hydraulic oil level #3
The trans holds so much oil, I would think + or - a little is it is not real critical. As long as it is in the window.
   / GC2300/GC2310 transmission/hydraulic oil level #4
Mine must be either very full or empty. There is a slight yellow tint when I look at the level site, so I'm assuming (hoping) that is the tint of the oil and not the color of the metal thingy that's behind the glass.
Is it? :confused:
Jay
   / GC2300/GC2310 transmission/hydraulic oil level #5
It is full. If you want to check for sure, find a hill or dip and point the tractor down hill. You will see the difference.
Doug
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
Unused 2025 CFG MH12RX Mini Excavator (A50322)
Unused 2025 CFG...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
