3-Point Hitch GC2300 3PTH Creep- Looking for a fix
   / GC2300 3PTH Creep- Looking for a fix #1
JDKu
Calgary, Alberta, Canada
GC2300
My tractor has around 700 hours. For the last 100 hours, the 3 PTH creeps down at random times. I often carry the rototiller for ballast when working with the FEL. It's a bit annoying as I need to be constantly lifting the 3PTH. Sometimes it will stay up for many minutes. Other times it will creep down in under a minute. If I adjust the "screw" thing that controls rate of descent and try to lock the 3PTH in the upper position, it doesn't seem to make any difference i.e. creep still happens. Does anyone know how to fix this?
   / GC2300 3PTH Creep- Looking for a fix #2
1. If it leaks down when the "screw thing" is turned in then the seal or check ball on the "screw thing" is leaking
2. The seals on the internal lift cylinder are leaking.
3. The 3 point lever is not fully returning to the neutral position - fiddle with it a little when the tiller is lifted up in the air.
CAT 430E BACKHOE LOADER (A50854)
CAT 430E BACKHOE...
2015 Volkswagen Jetta TDI Sedan (A50324)
2015 Volkswagen...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
2014 VOLVO VHD DAYCAB (INOPERABLE) (A50854)
2014 VOLVO VHD...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
