GC1715 OEM rear worklight
   / GC1715 OEM rear worklight #1
apps
Verner, Ontario
MF GC1715
Anyone replace bulb with LED? What did you use? Only markings on bulb are 12v 18.4w, bayonet style. Already have LED light bar forward facing & another LED rear worklight on left side. Might as well make oem light useful since I bought 3 pt snowblower.
   / GC1715 OEM rear worklight #2
Re: GC1715 OEM rear worklight bulb replacement
You need to match the bulb port type. Most people I've seen replace the entire worklight with a multi led work light to get better light flooding vs a single bulb replacement.
   / GC1715 OEM rear worklight #3
The problem you will find is that the worklight is on an Ignition HOT lead (because the worklight has it's own switch). If you go to an aftermarket LED, you will have to provide your own in-line switch as I have been unable to find an LED with an integrated switch. Just changing the bulb to LED doesn't work very well because the housing is designed for an incandescent bulb and it doesn't focus the light. BTDT
   / GC1715 OEM rear worklight #4
If you elect to replace the entire worklight with an LED array check your fuse and wiring capacity. Although an LED uses less power than an incandescent if you install an array type flood light you may overwhelm your circuit and regularly pop the fuse.
   / GC1715 OEM rear worklight #5
I put in an LED work light on an SAE connector with an in line switch and a split to a 2.1 USB charger port. Kept the LED down to 6 LED. Also replaced all 4 head lights with LEDs. Makes a good light show!
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2014 KENWORTH T800 (A52472)
2014 KENWORTH T800...
KARCHER WALK BEHIND FLOOR SCRUBBER (A52472)
KARCHER WALK...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
