GC1710 loader acting strange
   / GC1710 loader acting strange #1
99FrcVern
East Granby, CT
Massey Ferguson GC1710
For some reason I've noticed my fel is having a issue with the tilt function when I go to dump things. Its curls without a issue. But seems to hesitate when I try to dump. Any help would be great
   / GC1710 loader acting strange #2
First thing I'd do is double check your hydraulic fluid level of its while extending cylinders. Other than that are you leaking any fluids anywhere?
   / GC1710 loader acting strange #3
Check to make sure all the pivot points are tight and greased.
Do you hear any hydraulic noise on tilt like pressure being released?
The level on the sight glass is good. Im going to do a hydraulic fluid change tonight, I had a small leak on one of the lines going to the backhoe from a weak crimp but that was fixed a while back.
   / GC1710 loader acting strange #5
Your loader has a quick dump function I believe. When you dump, you can push the lever PART way or all the way .. can't remember which is the quicker dump function. Most people don't know this.
   / GC1710 loader acting strange #6
That's what I forgot to ask, did this just start or has this been going on since ownership?
   / GC1710 loader acting strange #7
It wants to know if your sure you want to dump it :) Your probably hitting a sweet spot between normal dump and quick dump.
   / GC1710 loader acting strange #8
I agree - always good to be polite and ask! haha
   / GC1710 loader acting strange #9
There is a chance that there is air in the system that has not bled out.
Raise the loader as high as you can, to invert the dump cylinders. Then cycle the curl function from full extend to full retract a few times.
Might purge the suspected air out.
   / GC1710 loader acting strange #10
I recall watching a video on YT some time back where a 1720 owner was having an issue with a joystick not fully functioning in one direction. Opened up the casing and saw that the pivot mechanism to convert joystick movement to hydraulic flow had come loose and was not linking properly. Something to look at if not found in any other suggested fix.
The odd time, my 2410 gives me bupkus when I ask for dump on the loader. It's not often, but when it gets bad, that is what I will be looking at.
2001 CHEVROLET W4500 12FT FLATBED DUMP (A52141)
2001 CHEVROLET...
Cat 953C Crawler Loader (RIDE AND DRIVE) (A50774)
Cat 953C Crawler...
BUYERS PREMIUM & PAYMENT TERMS (A52577)
BUYERS PREMIUM &...
Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A50322)
Toro Z-Master 6000...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50322)
2016 Hurricane...
