Gc1705 with old wheel horse plow and frame
   / Gc1705 with old wheel horse plow and frame #1
MFer1705
Allenton, Michigan
Massey Ferguson GC1705
I wanted to have a front plow to utilize in addition to my back blade. I had an old plow from a wheel horse tractor i wanted to try to install. I cut two links of a big chain off for each side then lynch pinned it to the tractor after connecting it to the existing brace of the plow frame with a u bolt. Connected a strap to an eye on the frame and then to that chain on bucket. With only 2 links on the back it makes it too short to sway back and hit anything on my tractor. I know i will need 2 longer lynch pins for strength. We are supposed to get a few inches of snow tonight so I can try it out. 1517680186583.jpg
   / Gc1705 with old wheel horse plow and frame #2
This is made from two Bolens tube frame plows.
Works great.
That's a really sweet set up
   / Gc1705 with old wheel horse plow and frame #4
Thanks. It was more of a test when I did it.
It worked so well, I just use the prototype.
You should try to find some thing to add some width to the blade.
I started with a 42" plow, and added the outer part of a second plow to each end.
   / Gc1705 with old wheel horse plow and frame #5
You guys got me thinking about my 60inch Moose plow I bought 13 years ago for my ATV. Its been sitting there doing nothing for 9 years. Ill just have to figure out how to adapt it to the bucket.
   / Gc1705 with old wheel horse plow and frame #6
I did not consider the bottom of my GC bucket heavy enough to mount even my lightweight plow to it, without the real possibility of damaging it.
I did not want to make the bucket heavier. So, I built a frame to mount the plow to.
It wasn't difficult to fabricate. And, eliminating the bucket allowed a shorter overall length.
   / Gc1705 with old wheel horse plow and frame #7
Ray, I have had a similar idea to do with a Cub Cadet plow blade (54 or 60 inch sizes). I already have a quick attach on my FEL - and I can get a "blank" quick attach plate I could mount to the plow. Then I could drop the bucket - in seconds and in seconds attach the plow so I could switch between the two easily and with little weight issues. But I ran out of time in 2017 - it will be a 2018 project :)
2016 CHEVROLET SIVERADO 4X4 PICKUP (A52577)
2016 CHEVROLET...
Ferris 52in Zero Turn Mower (A51694)
Ferris 52in Zero...
SKID STEER HYDRAULIC TREE PULLER (A52472)
SKID STEER...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52576)
2015 VOLVO VNL...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A52748)
2022 JCB 3TS-8T...
