GC1705 What Brand Battery Do You Like?
   / GC1705 What Brand Battery Do You Like?
My guess is the battery is just fine. A cold battery makes things worse so if it's in a building with holes in it where the wind can get in or maybe with a dirt floor, that makes thing colder than in a shop attached to the house. Things turn pretty slow at 2 degrees and windy.
Next summer, have a dealer install a block heater that will heat the coolant and you will be all set for next year. Don't try to put it in yourself unless you have done it before since lots can go wrong.
I know what you mean about the block heater.. I put an OEM in last summer, I tapped the plug on one side gently and couldn't get the plug out, I didn't want to tap the punch any harder, I called my brother (he is a diesel mechanic) he told me to take the punch and warp one edge and grab the plug with a pair of needle nose, I got it out no problems, I use it all winter, the tractor is as cold blooded as it gets so the block heater and tender is going to be needed in the winter months I guess..
   / GC1705 What Brand Battery Do You Like? #12
I lived north of Bangor for many years and with a block heater could start a diesel tractor with thick dino 15w40 like it was summer. The trick was a block heater and I left it in all night before I wanted to use it. Made all the difference. Tractor was in a nice barn but open on the flat ground where the wind could really get rolling. Wow, was it cold. When engines are new, like yours, they start harder.
Put an Interstate MT-51 500CCA fits perfectly and cranks well. $100. Didn稚 want to spend the money on the AGM.
   / GC1705 What Brand Battery Do You Like? #14
I've gone to Odyssey on my tractor. It has massive CCA and I do keep a battery tender on it. Both Optima & Odyssey are AGM type.
Love Odyssey batteries... Have 1500 hot cranking amps, 850 cold cranking amps. in Jeep for winching...
Dale
2013 Ford Explorer AWD SUV (A56859)
2013 Ford Explorer...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
1667 (A57192)
1667 (A57192)
2025 GPS Trailer (A56857)
2025 GPS Trailer...
(2) HD ALUMINUM RIMS (A58374)
(2) HD ALUMINUM...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
