Oil & Fuel GC 2610 Hydraulic Oil Level
   / GC 2610 Hydraulic Oil Level #21
If you cannot get the hoses to connect when you go to put it back on, the lines have built up pressure. You can loosen the hydraulic fittings for a few seconds with a wrench, or put a rag over the end of the hose, and tap the ball on the end of the fitting with a hammer a few times, to let off some of the pressure. They will connect easily after that.
Don't forget to hook the correct two hoses together on the tractor, before running the engine with the hoe off.
If you forget, the loud noise you hear is the pump telling you, your stupid. :thumbsup:
Thanks for the tip.
2015 AMERITRAIL MANIFOLD TRAILER (A58216)
2015 AMERITRAIL...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
2847 (A58376)
2847 (A58376)
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2016 Chevrolet Silverado (A57148)
2016 Chevrolet...
