cdaigle430
Veteran Member
When plowing today, I noticed that most of the time, one front wheel will spin when the other will not, and it varies as to which side it happens on. I though it was full lock once your in 4x4?
ray66v said:4wd actually only gives one drive wheel in the front, and one in the back at a time. So yes, this is normal.
You can use the rear diff. lock and have 3 wheel drive, if it becomes necessary.
Ray's Rite.When plowing today, I noticed that most of the time, one front wheel will spin when the other will not, and it varies as to which side it happens on. I though it was full lock once your in 4x4?
