GC 2400 Hard Starting
   / GC 2400 Hard Starting
Tractor is running, 60 minutes under the blanket with the heater did the trick.
   / GC 2400 Hard Starting #42
I guess you need a block heater now.
   / GC 2400 Hard Starting #44
Hey Don87, what kind of diesel fuel are you feeding your MF? During the winter, I use #1 winter blended off road diesel and also add power service from the white bottle, :thumbsup:. We have 2 fuel locations in my small town, and I always fill at the one that goes through the most fuel thinking I will get fresher fuel that does not sit in there tanks for along time, ;). Just a thought, put a small amount of fuel in a container and keep it with your tractor to look and see if the fuel has a gelling problem before you feed it to your MF? Good luck, KC :D :D :D
SET OF (4) TITAN MULTI TRAC C/S TIRES & WHEELS (A51244)
SET OF (4) TITAN...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
71069 (A49346)
71069 (A49346)
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
