GC 2325 blades
/ GC 2325 blades #1
blackd
Platinum Member
So MD
Yanmar FX24D replaced with Massey GC2400
Double posted in the GC2400 upgrades thread. Posted here for max visibility.
GC 2325 blades. The price of MF blades is crazy. Has anyone tried this combination? Oregon 91-584 with a 02-452 (3/4" X 1") adapter. Blade sp[ecs are: L 20 15/16" Ctr hole 1" W 2.5" and thickness .25". Total price for 3 blades, adapters and shipping is $48.08 (there is a 10% discount) from Lawn Mower Parts .
Except for the Ctr hole it matches the MF 3606888M1 blade.
Oregon blades can be found here: http://oregonchain.com/OEP/pdfs/2010...esByLength.pdf
/ GC 2325 blades
Same thickness. My dealer is charging $40 + tax per blade. The only issue may be the hole on the bushing. I think the shaft is right at 3/4", so if anyone has tried them, let me know.
/ GC 2325 blades #4
I found that mower blades for anything are crazy, my husqvarna blades at the box stores were around 22 bucks each for a 48" deck.
/ GC 2325 blades
Got the blades today. Laid one on top of an old blade and they are pretty close. Same length. Same width. Same thickness. The formed/drop section is shorter on the new blade. Don't ex[ect that to be a problem.
1" Center hole with 1" to 3/4" adapter to be tested for fit on spindle next. Won't get to it for several days. Will let your folks know results.
/ GC 2325 blades
Well I got around to trying to install the blades and the adapter is a touch too small. I will ream them out to fit the spindle, but not today.
My plan is to drop the right blade and use the nut to size the a bolt of that size and use that to measure when I ream the adapters to size. Remember this needs to be done only once as the inserts are reusable.
An addendum, it looks like the Oregon blades with a center hole of .822 are designed to fit the the metric (I am guessing here) spindles. I can not find a blade of the same width and thickness. Length of ~21 inches might work very well. Just a touch on the grinder of each tip should make them safely fit. Remember as soon as the blades are used the tips begin to wear.
Speaking of wear, around here, the soil is relatively sandy and the tips wear, but the back/lift side of the blade wears quite extensively. I get ~1 year out of a set.
So the decision is still ~$45-50 for a set versus ~$125-130.
/ GC 2325 blades
Update. Instead of buying a $5.50 20MM metric bolt, I took the spacers to the hardware and fit them there. They are fine. I chucked them into my vice and used a cheap harbor freight grinder that coincidentally is 20MM to enlarge the holes. A small container of water to cool them as I worked was needed. Total time to work them to the correct size was ~20-30 minutes. Now I can replace my expensive blades with these ~1/3 the price.
Now to install them and see if they last longer than the OEM blades. Now that I have spacers I might try alternative blade types with 1" center holes.
/ GC 2325 blades #8
don't mean to hi-hack this thread... I've read on several threads here about guys replacing mower blades frequently.
I mow about 2.5 acres of grass around the house, and some walking paths thru and behind the woods. I've had my Kubota TG1860G with 54" deck for 13 years and sharpen the blades 2 or 3 times a year.
I'm still on the original blades, they look fine--- what am I doing wrong ???
Pete
/ GC 2325 blades
You are lucky. Bring it down here and cut this ?grass? greenery and see if it lasts.
When I first moved into my 3+ acre lot, ~1/3 was wild black berry vines, and much of the remainder was covered with trumpet vines, the greener that holds SoMD together. We have dry spells nearly every year, guess what remains green during those spells? ;)
/ GC 2325 blades #10
blackd, got any pics of the mods, step by step?:thumbsup:
/ GC 2325 blades
Wacky, I didn't think pics were necessary. I guess I can take a pic of the old blade and one of the new, and the center hole adapters.
Once I have the new blades installed and tested I will report back. I just sharpened my existing blades so there is no rush for me to install right now.
/ GC 2325 blades #12
blackd, I'd like to see too... My back-fill soil is ALL sand (the price was right-- free), and I also find that's really hard on mower blades.
So far mine are holding up, but I did just swap the left blade for the right when I serviced the deck last week, as the tips on the far right blade are beginning to show some pretty good wear.... I can see it's only a matter of time before I'm going to want new blades.
/ GC 2325 blades
Well I finally got the technology issues straight on getting pictures and down loading. Pic 1 shows left 2 YO blade, middle 1 YO, and the new Landpride blade W insert. Pic 2 is the new blade and insert. I tried to show the wear on the blades and the packaging for the inserts.
It's so hot and dry here, I don't know when I will put the new blades on the tractor. But at least you can see what they look like
/ GC 2325 blades
Well, its time to update. Cut the yard for the last time yesterday. Will drop the deck and get ready to install the snow blower (that means we will not have any ya'no). The new blades worked great. I still do not know how well they held up. Will see after dropping the deck. Here's the real heads up. I installed the2 blades per spindle (new blades and the old blades), and that really worked well. Starting the deck will really slow the RPMs until they come up to speed, but they cut well. That's especially true when cutting the tougher weeds that grow here SoMD. Some fields would require two passes, but with this configuration I cut in one pass, and if necessary slow down.
I will be buying another set of those Oregon 91-854 blades with adapter 02-452 this Winter. I'll just wait for a sale/discount coupon.
/ GC 2325 blades #16
Well, blackd, I finally got around to servicing my MMM and digging out the snowblower last week.... Do I understand you correctly that you put two blades on each spindle like a "plus" sign? Interesting.
My blades are showing some pretty good wear now, but not as severe as yours. I've used the deck now for three seasons, I think.. maybe four, so the wear factor isn't terrible, but I still like the idea of avoiding $40 per blade. I can see where I'll be wanting some blades pretty soon.
/ GC 2325 blades
Crossed blades, exactly right. At the end of the season two spindles had the blades moved together as tightly as they could. One spindle was still pretty well the same as installed. Don't know why.
/ GC 2325 blades #18
I've noticed some shifting of blades as the season progresses, even though I set them at 90-180-90 whenever I put them back on... guess there's just a lot of stress every now & then, followed by some slippage on the belt drive. (I know I hit my share of tree roots & rocks!)
Just about to install the transmission pan heater that ray66 recommended.... But right now it's pretty warm with no snow at all up here; put 60km on one of my motorcycles today running errands.:D:D (Good thing it's fall, or I'd be removing bugs from my teeth, I was smiling so much....:laughing:)
/ GC 2325 blades
Well, its Winter and time to think about the mower blades again. I ordered a new set of the Knurled Bushing 3/4 X 1 02-452ORE 3
Blade, Woods 1001513 91-584ORE 3
from Mower Parts Free Shipping Same Day . Price was $50.77 for the 3 blades and the bushing inserts.
Now to open the bushing centers to 20MM. Then I'll be ready for Spring cutting.
/ GC 2325 blades
