GC 2300 Wont Start (need to by pass the safety switch to test)
   / GC 2300 Wont Start (need to by pass the safety switch to test) #21
Your welcome.
   / GC 2300 Wont Start (need to by pass the safety switch to test) #22
Similar problem today with my GC2300 which also has about 700 hours though not sure what year. Exactly the same symptoms as the original post here, though my battery was only 12.7v when checked with the meter.
Tried to jumper from the positive battery post to the positive terminal on the solenoid, but no result. Tapped on the solenoid a couple times with my pliers and it started immediately.
The next time I stopped to get off, I left the tractor running, though in neutral and with the PTO disengaged. As soon as I stood up, the tractor shutdown. After some fiddling I've determined that the PTO lever or the switch for the PTO is off kilter somewhat. A few times I had to hold tension on the PTO lever in the disengage position to get it to start. A couple times I did not. The lever doesn't seem to be coming back as far as it normally does, so when time allows I'll blow out the lever linkage and switch with the air compressor. It's been rather dry & dusty the last two months here.
I might not also have a starter solenoid going bad.
Thanks to all for the advice! It was a big help and I was only out of service for about 30-40 minutes.
   / GC 2300 Wont Start (need to by pass the safety switch to test) #23
Clutch safety switch by-pass question
I made a permanent by-pass for my clutch safety switch & installed it so I could start the tractor ( Jinma 254 ) without having the clutch depressed. It worked great while I was trouble shooting my starter problem.
However now that starter problem has been fixed, with the by-pass still installed and the tractor idling I depress the clutch and slide it into gear and the tractor immediately jumps forward . The by-pass shouldn't have any effect on the clutch disengagement should it ??? Any suggestions will be appreciated .
   / GC 2300 Wont Start (need to by pass the safety switch to test) #24
If pulling a fuse and replacing it solved problem, you probably have corrosion issues on fuse body (prongs) or in socket.....
Usually pulling and replacing fuse will scrape corrosion off fuse/prongs in fuse holder.... Suggest you clean up fuses and fuse holders and put very thing coat of dielectric grease on fuse prongs before inserting for final time, it seals out oxygen and moisture there for preventing corrosion... Only negative is it will hold dust and dirt...
Yes you will argue dielectric grease is an insulator and you are correct BUT if you have solid mechanical connections it just seals moisture and oxygen out ....
It has solved or prevented so many problems for me it has become a religion for me to use it....
Also for battery terminals...
Super clean battery posts and terminals (with soda to neutralize any acids) polish with scotch bright (contact surfaces) and apply liberally to post and clamp (may need to warm a bit - hot air from hair drier or heat gun as it is pretty stiff), you will not have battery corrosion issues... I do all my vehicles and never have corrosion at battery post/cable issues... One truck actually when 8 years without problem till battery internally failed....
Dale
   / GC 2300 Wont Start (need to by pass the safety switch to test) #25
My GC 2300 overheats after about 3 hrs of mowing. Obviously I shut it off, clean all of the screens, leave the hood open and let cool off before attempting to continue mowing. Sadly, it then won't start until the next morning! When I attempt to start after it overheating, the fuel pump clicks, so current is flowing, but the solenoid won't engage, no click or grunt from the motor, just nothing until the next day. The ground strap is clean, the battery measures 12v so this appears to be just plain weird. Does this machine have a thermal cutoff somewhere? If so, where is it located? I don't see one listed on the schematic that came with the tractor new. I've read the entire thread and tried all of the suggestions but other than pouring gasoline on it and tossing a match I'm clueless. Any help will be most appreciated. BTW, flushing the radiator and refilling with new coolant doesn't solve the overheating problem. SamO
   / GC 2300 Wont Start (need to by pass the safety switch to test) #26
Sam, sorry you are being frustrated by your tractor.
I suggest you start a thread, with your original post.
There is a better chance that people will see it then.
Your problem is unique. But, we will try and think of some things you can do.
The heat could be affecting the battery, which would explain the no start condition. I would load test it, cold, and hot, to make sure it's okay.
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
UNICARRIES MUG1F2A30LV FORKLIFT (A52708)
UNICARRIES...
LOT: (10) Wheel Loader Bucket Teeth (A59076)
LOT: (10) Wheel...
Meyer 8.5' Snow Plow w/ Bracket (A55272)
Meyer 8.5' Snow...
2017 CATERPILLAR 304E2 CR EXCAVATOR (A52709)
2017 CATERPILLAR...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A55973)
Okada OKB 304B...
