GC 2300 replacing Hydro unit fan
   / GC 2300 replacing Hydro unit fan #1
Ryan15
Worthington, Ma
M-F gc2300
Has anyone replaced this plastic fan yet. Is there a relativley easy way to do this. Took out every blade with a stick in the woods.
   / GC 2300 replacing Hydro unit fan #2
You should be able to loosen the lock bolt on the driveshaft to get it off the input shaft to replace the fan. I don't remember it being a big deal
Mfred,
I was under the little beast and I saw the clamp, but I can not see the engine end and do not know if it is splined and will allow the shaft to slide forward for the fan to clear.
   / GC 2300 replacing Hydro unit fan #4
Yes the front u-joint and yoke are splined at the motor and will just slide ahead to give you enough room to change the fan blade.
INMY Manual Landing Gear (A51692)
INMY Manual...
PAIR OF FRAME MOUNTS FOR VACUUM PUMPS (A53843)
PAIR OF FRAME...
2008 Cadillac Escalade ESV 4x4 SUV (A51694)
2008 Cadillac...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2014 Nissan Versa Note Hatchback (A51694)
2014 Nissan Versa...
