GC 2300 replacing Hydro unit fan
   / GC 2300 replacing Hydro unit fan #1
Ryan15
Worthington, Ma
M-F gc2300
Has anyone replaced this plastic fan yet. Is there a relativley easy way to do this. Took out every blade with a stick in the woods.
   / GC 2300 replacing Hydro unit fan #2
You should be able to loosen the lock bolt on the driveshaft to get it off the input shaft to replace the fan. I don't remember it being a big deal
Mfred,
I was under the little beast and I saw the clamp, but I can not see the engine end and do not know if it is splined and will allow the shaft to slide forward for the fan to clear.
   / GC 2300 replacing Hydro unit fan #4
Yes the front u-joint and yoke are splined at the motor and will just slide ahead to give you enough room to change the fan blade.
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
1261 (A50490)
1261 (A50490)
UNUSED RAYTREE RMBD72-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A53117)
2018 Mack PINNACLE...
UNUSED WOLVERINE GB-11-72W-72" HYD GRAPPLE BUCKET (A51248)
UNUSED WOLVERINE...
John Deere PT Land Leveler (A50123)
John Deere PT Land...
