GC 2300 mf 2350 loader parts
   / GC 2300 mf 2350 loader parts #1
67PLY
PENNSYLVANIA
MASSEY GC2310
Need part number for joystick handle for my MF 2350 loader - mine broke today close to the threaded part.
Thanks .........
   / GC 2300 mf 2350 loader parts #2
Couldn't you just rethread the handle and screw it back on?:confused: Would be cheaper than buying a new handle.;)
   / GC 2300 mf 2350 loader parts #3
Broke mine about 3 years ago, remove nut, unscrew threaded portion, weld back together, re-assemble--done!
   / GC 2300 mf 2350 loader parts #4
I don't see the handle listed separately from the entire valve.
The only other part is the knob.
As the others suggested, looks like you would be way ahead to fix it.
It is 8mm metric thread - will get a metric bolt + nut and weld to the handle .... thanks.
   / GC 2300 mf 2350 loader parts #6
Part Number Description Cost Per Item
71516035 LEVER $30.08
   / GC 2300 mf 2350 loader parts #9
Mine broke in a spot that did not take kindly to welding, which is why I bought the part and why I have the part number. It came from Jack's a a year ago. The price has dropped since I purchased. Price is for the metal rod, nut and lockwasher only. The knob unscrews and gets reused.
Thanks - mine just broke again.
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
GOODYEAR SET OF 420/85R30 NEW AG TIRES (A52748)
GOODYEAR SET OF...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
