GC 17XX Tillers - what are you using?
   / GC 17XX Tillers - what are you using? #1
rossn
Denver, CO
Massey Ferguson GC1705
Have a GC1705 and am curious what tillers people are using on their GC 17xx's, and how they are working out for you? Do you have a sub-compact version or run a standard compact version of a tiller?
I am seeing a variety of various tillers with different tilling depths. For instance, the KK XB has a advertised tilling depth of 6.5", whereas the non-XB version has a tilling depth of 8". I know ground clearance and weight can be a difference, but curious if some standards (non-sub-compact) versions work OK behind the GC17XX.
Thanks!
Ross
   / GC 17XX Tillers - what are you using? #2
I have a Taylor way 48" behind my GC1705. Works great and no problems in three years. Probably tilled a total area of 4 acres so far, not all at one time. :D
   / GC 17XX Tillers - what are you using? #3
I have a Taylor-Pittsburgh 48 inch and it does great. I bought it new with the tractor from the dealer. I used it to till a new garden this year in an area which has been in grass for years. Tore through it without any problems. I am getting ready to video tilling with it. Maybe tomorrow? We have had some rain every day for 3 weeks!
   / GC 17XX Tillers - what are you using? #4
I have a standard cat 1 48" king kutter gear drive tiller. Works like a charm. I've used it in gardens and in clay soil alike with no problems at all. I have a gc1710.
   / GC 17XX Tillers - what are you using? #5
I have a BX25 and am planning to buy a tiller this week. Take a look at the videos of the everythingattachment tillers on youtube - especially the ones about the construction. I say that as it will educate you on what to look for in a tiller. In this case, Everything Attachments Chain Drive Rotary Tiller 48" - YouTube . The only thing he doesn't mention in that video is there are two shapes of tines - L and C shaped. In other vids, he mentions that the C shaped is his preferred as it cuts better than the L shaped. Guess it depends on your soil type whether it makes a difference or not.
   / GC 17XX Tillers - what are you using? #6
Just moved but had a Gc2400 and ran a 5ft KK. Worked just fine and often ran it at about 1700 rpm. 540 pto is at 2500 so it pulled it easy. If I was to do it over I would get another 5 ft KK. Ed
   / GC 17XX Tillers - what are you using? #7
I too have a GC2400. I've had 2 tillers. 1st was a 7 foot Yanmar. It tilled great and the tractor was capable of running it, but it was too big to transport on the tractor as the tines hit high spots in the road. I go ~1 mile on the road to till a friends garden. I now have a Caroni 48 inch tiller. Tills as good as the Yanmar, but transports better.
BTW, for me the tiller is the most difficult to attach. I now take it into the workshop concrete floor and adjust the arms to the height of the tiller and connect to the PTO as they match up better. When younger I would just man handle the thing, but those days are now gone. We old guys learn, sometimes the hard way. ;-)
   / GC 17XX Tillers - what are you using? #8
I have really thought about the quick connect ends for my tractor. I leave my tiller inside the shop on concrete, but it is still one of the toughest pieces of equipment to hook up.
All, thanks for the great feedback. Besides generally educational, it was good to learn that a few of you are running the regular KK 4' and 5' tillers fine with the 18.7HP PTO.
I had another thread about tilling depth, where the poster mentioned that due to weight and size, I wouldn't be able to run the 4' regular KK. He also advised against the land pride RTR0550 because he said RTR requires more HP than I have.
I actually may be able to pick up the a land pride in like new condition for about $1000. Thoughts on 1) if the GC1705 tractor will drive it OK in soil with high clay content and b) the fact it only has a 5" tilling depth? Should I pursue this or pass for a deeper tiller that is not RTR?
Thanks!!
   / GC 17XX Tillers - what are you using? #10
I bought my Land Pride tiller with the tractor new. I tilled over 3 acres with it last Spring, and it did fine. Getting it adjusted correctly on the 3 pnt will come with experience. IMO, tilling deep isn't good for your soil. 5" of tilling depth is plenty.
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
JOHN DEERE LOT NUMBER 138 (A53084)
JOHN DEERE LOT...
New/Unused 7ft 10 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 10...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
