GC 1715 drive train ratio
   / GC 1715 drive train ratio #1
Bruce T
Vinland, WI
Massey Ferguson GC1715
Does anyone know the final drive ratio for the 1715. (how many revs up front for every one Rev in the back)
I'm looking at ag tires and need the drive ratio to figure out the lead/lag for the 4wd. Thanks
   / GC 1715 drive train ratio #2
You can calculate it off the tires on the tractor already, or at least get close enough for ag tires... OR just go with the size you have now, which is the factory offering in ag, turf, and industrial according to TractorData.com (The factory doesn't change ratios depending on your tire selection...)
If you can find larger tires and want them, just be sure to go the same percentage bigger front and rear.
If you're bad at maths, measure the height of the current front or rear tire as best you can. Find your preferred larger size for that tire, and divide the current tire ht by the ht of the larger replacement tire. That gives you a number like 1.10, which would mean your new tire is 10% larger than old. Now go find a tire for the other end of the tractor that's also 10% larger than the stock tire for that end. (Multiply the measured height of the current tire by 1.10, find a tire that height)
Make sense?
FYI, it appears that on my tractor, the ratio equates to the front and rear tires covering the same ground with the industrial tires, but the ag tires for my particular tractor did provide about a 5% lead on the front axle by the height numbers. I assume the tread on larger AG tires squirms a bit more, so forgives the lead going straight, and the slight lead makes turning easier... ?? By that example, I'd not worry if you wanted oversize ag tires, and the fronts were up to 5% larger than "ideal" numbers suggest. At worst, you'd get faster wear on hard surfaces in 4wd, but why would you be operating like that, especially with ag tires??
Thanks for the tip. Based those numbers I should run a 19 front tire. The ones I'm looking at are 20". I can't imagine that would matter on the little scut. I'll leave the original turffs on most of the time. Only need the ags for cutting trail where I deer hunt.
FYI, front axle lead ratio is 3.12% for the gc2300, I'm thinking its the same for all the GC's. Found ratio here on tractorbynet
   / GC 1715 drive train ratio #4
Glad you found it; I had forgotten how much the lead was and couldn't locate it in my manuals when I looked the other day --sorry. I was also betting that all the GCs were the same. (Now to remember it: 12%!)
   / GC 1715 drive train ratio #5
dealer installed ag's on my gc2410
26x12.00x12 rear
18x8.50x10 front
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
1994 GMC SIERRA C3500 DUALLY TRUCK (A51247)
1994 GMC SIERRA...
