GC 1705 60 amp alternator fuse location.
   / GC 1705 60 amp alternator fuse location. #1
ed's field mowing
massey ferguson gc1705
I am trying to find out if anyone knows where the 60 amp in line I think alternator fuse is actually located on a 2018 Massey GC1705. I have torn wires apart near and below coming off the alternator for over 18" and found nothing. I have a new alternator that checked out at shop to be working correctly but am getting nothing to battery. The 40 amp in the box by main fuse box is not the one I am looking for.
   / GC 1705 60 amp alternator fuse location. #2
There is no 60 amp fuse......Only the 40 amp fuse #11 on the GC 1705/10/15/20 series tractor...
Part number 29 in diagram.... IF you don't have 12Volts at "B" terminal of alternator you have open circuit on path, through fuse back to 12 Volt terminal on starter solenoid....
View attachment 995234.........
Got it fixed thanks it was the 40 amp fuse that looked good but texted bad
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2025 DORSEY ALUMINUM FLATBED TRAILER (A59575)
2025 DORSEY...
CFG Industrail MX15RX (A53317)
CFG Industrail...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2013 Ditch Witch XT855 Tracked Loader (A56436)
2013 Ditch Witch...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
